Archive
Hello all,
I am not a technical person I don’t have in depth knowledge about computer, just a beginner. The problem triggered when I try to open a PDF from the Web and same error appeared when I try to open a different PDF which I got in the Email. But there is no problem with the PDF files in the hard drive. How to solve this error? Any suggestions please help me. Thanks in advance.
Adobe Reader
Adobe Reader could not open ‘3D_Model_Preciew.pdf’ because it is either not a supported file type or because the file has...
Read moreHello Teac Savvy,
When I try to install AutoCAD 2012 latest version in Windows 7 64-bit operating system, I ended up with an error message and it stopped the installation. How do I continue with the installation? I tried to reinstall in several times but nothing seems to work. Really, I am in help. Please assist me solve this problem. Thanks in advance.
AutoCAD Warning
The following shortcuts in the search were invalid and ignored:
SAutodeskFSE - Acad Standards & TemplatesPlot StylesAdd-A-Plot Style Table Wizard.lnk
OK
Read moreHi tech savvy,
I am getting a weird error message when I try to install the Adobe Photoshop. The installation went good without any problem. The error message pops up when I try to open Photoshop. I tried the general method by reinstalling Photoshop blindly but no luck. How do I fix the missing dll file? Where I can download it? Please help. Thanks.
Adobe Photoshop CS6 Photoshop exe- System Error
The program can’t start because onOneCoreFoundation.dll is missing from your computer. Try reinstalling the program to fix this problem.
OK
Read moreHi troubleshooters,
I just started to learn Android Studio; the download and installation was successful without any issues. When I about to start the application I was stuck up with an error message. I am not sure whether this is compatible with Windows operating system. I tried to reinstall it several time but nothing works. After a search, I installed Microsoft Visual C++ 2010 Redistributable Package still I am getting the error. How do I fix this error? Help please.
studio.exe – Unable to Locate Component
This application has failed to start because MSVCR100.dll was not found. Re-installing...
Read moreHi expert friends,
At work, I need this in the computer to interact with the client. Therefore, I tried to download the Psi in the computer and I install it without any problem. I am almost to the end of setup, in the end I got an error message. I am confused with the error message, what I have to click now. How will I setup the new account? Help please. Thanks.
Server Authentication
The gmail.com certificate failed the authenticity test.
Reason: The hostname does not match the one the certificate was issued to
Continue Details Cancel
Read moreHi experts,
I have a problem with Android Studio; I am getting an error message. The problem triggered only after the update, before update it used to work to the core. I tried the link in the log window to set up the grade nothing seems to work. I tried all the option in the list but no luck. How I can solve this error? Thanks.
Resolve error
Gradle version 1.6 is required. Current version is 1.8-20130730220035+0000.
Please fix the project’s Gradle settings.
Consult IDE log for more details (Help I Show Log)
OK
Read moreHello everyone. I am trying to install 3dsmax on my windows 8 pc but I keep getting an error. I do not think that the problem is with my pc because I have just bought it recently. My specifications :
CPU: i7
Ram : 8 GB
VGA : GT640
Someone please help me, I really need this to be solved.
The application was unable to start correctly (0xc000007b). click OK to close the application,
Read moreHello troubleshooter,
I created a new account in the client place using Psi. The process went almost to the end. However, I got a warning error message saying it failed the authenticity test and the certification is self-signed. I am very confused what do I do now? Do I need to reinstall it again? Please help, your help is great.
Reason: Certificate is self-signed.
Read moreHello expert friends,
Recently I have updated some application in the computer. I have updated the Adobe application and Antivirus to the latest version. However, I am facing an error in different program; I get an error message in Google talk service. I tried repeatedly but nothing works and I tried to reboot the computer but no luck. How do I fix the following error? Please help. Thanks.
Connection Error
Could not connect to the Google Talk service (Error 1).
Retry Cancel
Read moreHi all,
When I am working around with layers, I am getting this error message. I do not understand the reasons for the error. The error triggered when I try to copy layers in the clipboard and it is not allowing me to work with the layers. Does anyone know how to fix this problem? Please help. Thanks.
Adobe Illustrator
Error 8705: Target layer cannot be modified
Line; 531
-> Var g = doc.groupItems.add();
Read more
