Archive
Hi friends,
When I try to install the Adobe Flash Player, installation went good to some level. Suddenly I got this error message ‘copy error’ it gives me only two options either to retry or cancel. Anyhow installation stopped I am not able to continue. This means the dll is corrupted, how do I copy this dll file in the directory? Help please.
An error occurred while copying file Download.dll.
Cannot copy file to destination directory.
Click Retry to retry the operation or click cancel to
Read more
Hi Friends,
When I am trying to install the Photoshop CS4 I am getting this error message ‘System Requirements error’. And it allows me only to quit from installation. The operating system is Windows 8 64 bit and I have 500GB hard disk; there is lots of empty space. But why I am getting this error message? Please help.
System Requirements Error
This Software cannot be installed because the file system of the OS volume is not supported. The OS volume should be local , writable and should have non case-sensitive file system.
Read more
Hello troubleshooters,
Thought of having new Antivirus, I started installing the Ad-Aware Antivirus in my system. For your information I am having Windows XP 64 bit with 4GB RAM and currently having AVG Antivirus. I cannot have two antiviruses in my computer. Do I need to uninstall one? I tried to uninstall the AVG and then I tried Ad-Aware again, but no result still I am getting the same error. Please help me to sort the error. Thanks in advance.
Installation Error
Ad-Aware has encountered an error during installation. We are sorry for the inconvenience.
Please close the program...
Read more
Hi experts,
I am experiencing this error when I try to publish my iMovie project. The error message states that, the problem has been caused by some plug-in. What might be the root cause? Do I need to install the Time Machine? Does anyone know how to fix the error? Please help. Thanks a lot.
The application iMovie HD quit unexpectedly.
The problem may have been caused by the lib3ivxEnc.dylib plug-in.
Mac OS X and other applications are not affected.
Click Relaunch to launch the application again. Click Report to see more details or send a report to Apple.
Read more
Hi Ally,
I am getting a weird error message; I am not able to use the DAZ Studio and Photoshop in the project. I don’t have in depth knowledge in these applications finding very difficult to handle this. For your information, I have a Windows Operating system 32 bit, DAZ Studio 32 bits and Photoshop CS 6 32-bit version on the computer. Please help me to get off out of this error, very confused. Thanks in advance.
Install Manager cannot find a required [path. The installer for “Photoshop 3D Bridge for DAZ studio 4.5+ (Win 32-bit)” requires...
Read more
Hello all,
I am getting a weird error message in the windows operating system. The Java download and installation was successful without problem. I tried to reinstall java several times but nothing seems to work. I don’t understand why it is happening. Please help me resolve this error any help would be appreciated. Thank you.
Java threw an excetion.
Read more
I have Corel Video Studio in the computer for more than months; it was working to the core without creating any problem. Now all of a sudden I am getting an error message saying that unspecified error and has stopped functioning. I tried to repair it but I am not able to do it. Please help me to reset the Corel Video Studio I need help for it. How I can solve this error? Please help me. Thanks in advance.
The program has encountered an unspecified error and has stopped functioning.
Please contact Corel Technical Support and...
Read more
Hi Professionals,
I have a problem with Microsoft Access, I think. When I try to update a record in SharePoint 2010 List connecting with Microsoft Access 2010 I ended up with an error message. This is not happening often; in rare case I see this error. How to solve this error? Please help me to fix the error.
MS Access
Data cannot be inserted because there is no matching record.
Read more
Hi there,
I am facing a terrible problem with Avid Media Composer; I am getting an error message when I try to start it after installation. Whereas I did not face any issue, while installing Avid in the Mac system. It was quite easy and smooth process. Why I am getting this error? I tried to install it again several times but nothing seems to work. Please help. Thank you.
The application was unable to start correctly (0x000007b). Click OK to close the application.
Read more
Hi friends,
Recently I upgraded the current Light Room version to Light Room 3.6. The installation was successful without any issues. But the real problem triggered when I attempt to export to .jpg or .dng. I ended up with an error message. The error message states that ‘an internal error has occurred’ I have only one option ‘ok’ , the file is not exported. Please help me to resolve this error. Thanks.
An internal error has occurred: Win32 API error 2 (“The system cannot find file specified.”) when calling ShellExecuteExW from Agworkspace.shellExecute.
Read more
