Archive
When I try to install the Suite I ended up with an error message. The error message states that MD5 check failed. I don’t understand the error message and I am not aware of this error message. Do I need to configure anything before installation? Please explain me in detail. Thanks
MD5 check failed for the current file to be staged, the file may be corrupt.
IDS_FILEC:DOCUME~1RODMAU~1LOCALS~1Temp{2FD6FAC4-5DC8-4175-9DAB-4D3FF5E30D53}{0FEA1B66-A7CC-4896-B273-CA977D72BBDD}setup.exe
Read more
Hi Friends,
Clipboard Help and Spell check installation went successful without any abruption. But when I startup the program error appears, operating system is windows 8 64 bit. What helps me to solve this error? I tried by trouble shooting the program by step by step but not able to guess the error? I cannot fix it. Help please.
Error DB65: DBISAM Engine Error # 11013 Access denied to table or backup file ‘query (129241)’
Read more
When I upgraded my system hardware last week, I also tried to upgrade my Windows Media Player. Upgrade went pretty good, but the problem rose when I try to play audio file. I tried to re-install the media player, but the error message appeared again. Is there any problem with the installation? Any file is missing in the installation? Please help me to find the error. Thanks.
No combination of filters could be found to render the stream.
Error Num:80040218
Read more
Hi Tech experts,
I haven’t made any change in the computer in the past, at the same time I don’t have any experience in that. When I tried with the WinZip Self Extractor, it failed to extract with the error message. So again I tried in different folder but no luck I am getting the same error. Why I am getting this error? I am not able to figure out where the problem exists. Please help. Thanks.
Unable to create a temporary folder to extract to.
Possible Cause: you do not have proper permissions to create files or...
Read more
Hello friends,
When I try to launch the Avast I ended up with an error message. The error message says that some dll file is not there. I tried to re-install the application, but again I ended up with the same error message. And also I tried to repair the application by going to control panel, nothing worked. Please help me to sort the error. Thanks.
This application has failed to start because MFC71.DFF was not found. Re-installing the application may fix this problem.
Read more
Hello experts,
I am getting this error in Adobe InDesign while I am working. Then I tried to do the process again but the error persists. Is anything terribly wrong? Do I need to re-install Adobe InDesign again? Please help me to trap the error and guide me solution. Thanks.
Adobe InDesign is shutting down. A serious error was detected. Please restart InDesign to recover work in any unsaved InDesign documents.
Read more
Hey,
When I try to play a video file in the KMplayer, I get an error message. Getting a bid scared of this error message ‘containing error’. I downloaded it from the authorized website after reading the reviews. Is any problem with the player? Do I need to uninstall the player? Whether this player might damage my system? Totally confused, please help me to solve this error.
C:Windowssystem32URL.DLL is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or...
Read more
Hi Brainy,
After the Avisynth update to latest version I am getting this error message. I updated from old version to new version, it works to some extent. Why I am getting this error? I never faced this error in the previous version. How to fix the missing dll? How to uninstall old one in proper way? Your help is great. Thanks a lot.
Avisynth open failure:
Script error: there is no function named “TDecimate” (C:UsersJordadnDesktopTS MKV 29.avs, line 2)
Read more
Hi friends,
I downloaded Jasc Paint ShopPro8.0 in the computer when I try to launch it the problem triggered. I got an Application Virtualization Error message saying the directory name is invalid. I don’t understand the error message. How to rectify this error? Please help to solve this error. Thanks.
The Application Virtualization Client could not launch Jasc Paint Shop Pro 8 8.0.0.0.
The directory name is invalid.
Error code: 45242F4-1F702339-0000010B
Read more
Hi trouble shooters,
I recently upgraded my system memory speed from 4GB to 8GB and also I formatted my hard disk. Now I have windows 8 operating system everything went good, the problem is I am not able to capture the audio in Bandicam. Did I go wrong anywhere in the previous things? I am not a technical person, so getting tired of this error message. How will I get rid of this error? Please enrich me with some ideas. Thanks.
Failed to start audio capture.
If you need to help, click the OK button.
Read more
