Archive
Hello Tech Experts,
When I try to view the video file in Windows media player I am getting this error message. This means the video card is not supporting the system. Do I need to upgrade the memory in my laptop? Can I use the new video card? I don’t understand where the problem is exactly? Please suggest me some solutions. Thank you.
TV and video may not work as expected because the video card does not meet the minimum memory requirement of 64 MB of video RAM. If you consistently encounter errors with TV or video,...
Read more
Hello Experts,
When I am in process of uninstalling the Kaspersky Internet security antivirus from my computer, I stuck up with an error message. Uninstallation progress was just started immediately I got this error. I have an idea of having AVG antivirus so I don’t need this Kaspersky. I don’t understand what the problem is about. Means I cannot uninstall? Please help.
Error 1316.A network error occurred while attempting to read from the file C:WindowsInstallerkavkis.msi
Read more
Hi Pro,
Whenever I start my system I am seeing this error daily and also sometime I get this error during shutdown too. I am not opening Windows media player but still getting this error. Is there any problem with WMP? Do I need to reinstall it? Are it is affected my any virus? How do I know? Please help me solve the problem. Thanks in advance.
Component ‘wmp.dll’ or one of its dependencies not correctly registered: a file is missing or invalid
Read more
Hey,
When I try to install the Final Cut Studio I ended up with an error message. For your information I have MacBook Pro OC x 2.2 Ghz Intel Core processor and I have LION installed in the system. Do I need to re-install? Uninstalling LION will help me? I am very confused please help me. Assist me to find the solutions.
You can’t open the application “FinalCutStudio.mpkg” because PowerPC applications are no longer supported.
Read more
Hello tech savvy,
I installed Zune in my computer and it was a successful installation. But the problem triggered when I try to connect my phone LG Optimus 7 with the computer. An error pops up when I try to read it. So I tried the method of disconnecting and reconnecting, but no luck. Help please.
READ ERROR
The Zune software can’t access important data on your device. Try disconnecting and reconnecting it.If the problem persists, contact customer support.
Read more
Hi Experts,
I need help badly; I am not able to use most of the applications in my computer. Something went totally wrong; I get this error message when I open any application. How do I find out which application made this problem? Please suggest me some ideas to get rid of this error. I need help very badly. Thanks for your help.
The application was unable to start correctly (0xc0000018). Click OK to close the application.
Read more
Hello Tech Experts,
After the Avisynth update to latest version I am getting this error message. I updated from old version to new version, it works to some extent. But all of a sudden I am getting this error. The video graph failed means; do I need to restart the program? Please help me resolve the error. Thanks.
Avisynth Error Message:
DirectShowSource : The video Graph failed to restart after seeking. Status = 0x80004005
Read more
Hello Pro,
When I try to partition the new hard disk using the Macrium Reflect 5 I ended up with this error message. Partition went good without any problem, but the problem is with the space. For your information I was trying to copy a disk from 75 GB to 200GB, I have ample amount of space. How come there is insufficient space? Please help.
Not all partitions copied. Insufficient space.
Read more
Hi-ya
When I try to install the Beyond CVS into Eclipse for using it in Beyond Compare integration, it went well and good. And I configured with external tools that too went good. The problem appears when I try to execute them. I don’t understand the error, is the problem with merging? Is there any problem with the Beyond CVS plug-in? Please help me to find the problem. Thanks.
An error occurred while trying to compare revisions
Exception: The Beyond Compare executable could not be found.
Please check your preferences and enter in the correct location for Beyond Compare.
Read more
Hi expert friends,
While I am working in Cubase 5 all of a sudden I am getting error message. I think it’s a serious problem, It is not allowing me to work further. It is asking me save the project before crashing. I saved the project and I restarted it again but I am getting same error. Please help. Thanks in advance.
A serious problem has occurred: Please try to save your project under another name and then restart Cubase5.exe. If this problem persists please contact Steinberg Technical Support with a description of what you do to...
Read more
