Archive
Hello there,
I have this error with this software which was recommended by a friend of mine. I want to find out if there is a problem with my laptop. It seems it is and none of us can fix this and I think we are good to PCs but we are stuck with this error. Please experts help us to fix this and maybe you can tell what and why this error appeared.
Thanks!
RegSvr32
The module ‘RtdHandleServer.dll’ was loaded but the call to DllRegisterServer failed with error code
0x80070005.
For more information about this problem, search online...
Read more
 Hello experts,
I ran a DLL fixer and reinstalled the Tiberian Sun, rebooted the PC and the DLL files still missing from my PC. I want to copy manually the DLL files but I don’t know which one is missing. Can anyone please tell me how can I fix this DLL files error? Is there a way to fix this without reinstalling the Windows 7?
Thank you!
Tiberian Sun
One or more DLL files were missing or damaged. Please reinstall.
OK
Read more
Hello there,
This morning this error appeared when I tried to connect to my cousins PC. I would like to make the necessary updates but as you can see in the error image I am asked to update my software. Can anyone help me with this error? Is it necessary to do so?
TeamViewer
Your partner uses a newer vresion of TeamViewer. Would you like to update TeamViewer now to establish a connection?
No
Thanks!
Read more
Hi there,
I made an update to my Windows 7 and it messed up my Microsoft Visual Studio. I reinstalled the program but now is not working at all. What is happening with my laptop after the update? How can I solve this without reinstalling the Windows 7?
Thanks!
Could not load file or assembly AjaxControlToolkit.
Version=1.0.10301.0, Culture=neutral, PublicKeyToken=28f01b0e84b6d53e or one of its dependencies. The system cannot find the file specified.
OK
Read more
Hi!
I have this Windows Installer package. I don’t know what it means and why I have it. I am a newbie with the PC and I am trying to use an iCloud because it seems like everyone has one now. I want to learn a little bit of everything but I am stuck when such error appears. Please help me solving this and if it is possible please tell me more about iCloud or recommend me to read an article
Thank you very much!
iCloud Control Panel
There is a problem with this Windows Installer package....
Read more
Hi experts,
I have this connecting error from Spectrum Digital and I did everything that the error says hoping that I will solve the problem. Nothing what is written in the error works and I am out of ideas. Does anyone have some time to help me with this ? What is wrong ?
Thanks !
Spectrum Digital XDS560V2 STM LAN Emulator_0/CortexR4
Error connecting to the target:
(Error -2062 @ 0x0)
Unable to halt device. Reset the device, and retry the operation. If error persists, confirm configuration, power-cycle the board, andor try more reliable JTAG settings (e.g. lower TCLK)
(Emulation package 5.1.45.0)
Cancel...
Read more
Hi there,
I have recorded something with Camtasia Studio and when I want to open what I have recorded this error appears. I have the latest version of QuickTime Player and I don’t know why this error still appear. Can anyone help me with this error ? What could be the problem ?
Thanks !
Camtasia Studio
Unable to launch movie player (0x2) for “C:UsersOwnerDropboxPlano and SimpleTRAININGHiwTo – Plano&SimpleWebsite overview 6Website overview6.mp4”.
There may be no application associated with the given file name extension.
Please try running the latest version of QuickTime Player and opening this file in order to view...
Read more
Hi there,
I have difficulties when I want to install some softwares. This is one of them. I don’t have any solution for this. Can anyone help me to fix this kind of errors ? What can be the main cause of this error and how can I prevent this to happen again ?
Thank you !
BeamNG.drive.x86.exe - Bad Image
C:Windowssystem32X3Audio1_7.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation software media or contact your system administrator or the software vendor for support.
OK
Read more
This morning McAfee came up with this error and tells me that it doesn’t have sufficient privileges to start. If I click Ignore nothing is happening but is not running and if I click Retry the same error appears again. Does anyone have any idea how can this be solved? Is there a problem with antivirus or with my Windows XP? Thank you.
McAfee VirusScanEnterprise Installer Information
Error 1920. Service McAfeeFramework (McAfeeFramework) failed to start. Verify that you have sufficient privileges to start system services.
Abort Retry Ignore
Read more
Is for the first time when I cannot update my McAfee AntiVirus and I try to make the necessary updates for 2-3 days. I have the full version and it was activated with a serial, so I have the full version which shouldn’t be a problem updating it. Can anyone tell me what could be the problem with my antivirus ? Why I cannot update it ?
Thanks !
Update Problem
McAfee cannot update your software. Please check your Internet connection. If the problem continues, please contact Technical Support.
Dismiss
Read more
