Archive
Hi there,
For two days I have this error message and I don’t know how to fix it. It appears every time my PC logs on. I don’t remember installinguninstalling anything lately so is a little bit weird for me to have this error. Does anyone know what is happening with my PC and how can I fix this error?
Thanks!
FineObjects
Cannot load unicows.dll. Press Cancel to terminate application.
OK Cancel
Read moreHi there,
This error appeared while I was working in Azure Storage Emulator. I have verified the processes and is not used by another process and this error still appears. Can anyone help me to fix this one ? What could be the another process that is using Windows Azure Storage Emulator ?
Thank you !
Storage Emulator
The process cannot access the file because it is being used by another process
OK
Read moreHi there,
This morning I got this error when I tried to connect to my home wireless network with my phone. It says that no connection was found and I have verified everything, the Internet connection is working, wireless is activated and I made a new connection on my phone. Does anyone have any idea about this error ? What could be the error ?
Thank you !
Unable to Complete Setup
No Connection Found
Your connection to the wireless network is turned off. Restored your connection and try again.
Exit
Read moreHi there,
I have this error in OS X and I don’t know why is not compatible with MailChimp. I have completed all the required fields for the MailChimp and still this error appears. Does anyone have any idea about this error? How can this error be solved? Thanks!
Your form’s fields may be incompatible with MailChimp!
Please match a field to the required MailChimp “EMAIL” field.
Help OK
Read moreHi there,
I subscribed to a game so I can receive the newsletter. One of this newsletter came with an update and when I tried to make an update this error with Can’t upgrade appeared and I need to verify the subscription. Can anyone help me to fix this error ? why my subscription is not valid ?
Thank you !
Can’t upgrade
Sorry, there was a problem while verifying your subscription.
OK
Read moreHello,
During the Compatibility Check this error and warning appeared and I am stuck with it. I don’t even know what this means and how can it be solved. Does anyone have any idea how can this be solved? What this error means? Thank you!
Compatibility Check
Error:
- Course 'OneMan' is a relay or one-man relay.
- Course 'Relay' is a relay or one-man relay.
Warning:
- Option 'Full stop behind control number' : Removed
- Option 'Number of start' : Removed
OK Cancel Help
Read moreHi experts,
I have this error from my portable app. I am a newbie this kind of apps and is my first error of this kind. Since I don’t have any experience I don’t even know what it means and what is causing this one. Can anyone help me to fix this error ? What could be the problem ?
Thanks !
Look up any Windows error code to find out what actually means.
We also have an offline and portable version for Windows available for download.
Error Code: 0x23D
Description: (Missing System File) The required system file %hs is bad...
Read moreHello,
I have this message from JetClean and I don’t know what it means or what it wants. I don’t want to reset my Start menu as the message says so I clicked Cancel. When I want to open the program again this message also comes again. Does anyone have any idea what it means? Thank you!
JetClean
WARNING about “Menu Order Cache”: Your Start menu will be reset. No items will be removed.
Are you sure you want to select the item?
Do not show me this message again.
OK Cancel
Read moreHi there,
I have this message error when I want to create a Bucket. I am not sure what could be the problem but I can’t create a Bucket at all. I tried to use lots of name with number combinations but nothing it seems to work. Does anyone have some time to help me creating this one? Thanks!
Create Bucket – Select a Bucket Name and Region
The requested bucket name is not available. The bucket namespace is shared by all users of the system. Please select a different name and try again.
A bucket is a container...
I’ve made some updates to my Windows 8 and I had to reinstall my Webcam. During the install this error appears and is telling me that my Webcam is not compatible with Windows 8. Before the update the camera worked great and now is not working at all. Can anyone help me to fix this camera error please ? What could be the problem?
Thanks !
Microsoft Camera Codec Pack Setup
This version of the Microsoft Camera Codec Pack is not compatible with Windows 8 or Windows Server 2012. You can get the codec pack though Windows...
Read more
