Archive
Recently I made an update to my Windows 7 and today this error appeared. I don’t know how to fix this and a friend recommended to install and run a DLL fixer. I don’t know what to say about this and that’s why I would like to ask you first for a solution. Should I install and run a DLL fixer on my laptop? Can you offer me an alternative solution that will work 100%?
Thank you very much!
cAudioFilterAgent.exe - Bad Image
C:Windowssystem32Avrt.DLL is either not designed to run on
Windows or it contains an error. Try installing the...
Read moreHi experts,
I don’t know why I can’t install this plug-in to my Winamp. I have this error that is saying that I need to have a Winamp 5.5+ version. My Winamp version is 5.5 and I still cannot install this plug-in. Can anyone help me to fix this error? Please tell me the steps to install this plug-in without reinstalling my Winamp.
Thank you!
NuIlSoft SHOUTcast Source
You are attempting to use the NuIlSoft SHOUTcast Source plugin in an unsupported version of Winamp or in a non- Winamp install. To work, this plugin requires Winamp 5.5 an higher or...
Read moreHi there,
This is my first error after I updated my Windows 7 (x86). After update I ran a DLL fixer so I can be sure that nothing is missing. It seems like something is missing, this DLL file. I have installed the DLL file manually and I still didn’t get rid of this error. Can anyone help me to fix this error without reinstalling my Visual Studio? Or my Windows 7 please?
Thank you!
Microsoft Visual Studio
A reference to ‘C:Program FilesMicrosoft SQL Server Compact
Editionv3.5sqlcecompact35.dll could not be added. Please make sure that the file is accessible, and that...
After I connected my iPhone to my laptop this error message. I am a novice with PCs I don’t really know what it means and how this error can be solved. Does any can help me please to solve this error? What this error means and why I have this error?
Thanks!
RA95.EXE - Entry Point Not Found
The procedure entry point SMapLS_IP_EBP_12 could not be located in the dynamic link library KERNEL32.dll.
OK
Read more
Hello experts,
Last night when I closed my PC I had some errors before he stopped. Now this morning when I turned on my PC this error appeared on my desktop and if I click OK nothing happens, is working just fine. The problem is that sometimes it appears unexpectedly. Is a little bit annoying this error and does anyone have some time to help me fixing this error?
Thanks!
javaw.exe- Entry Point Not Found
The procedure entry point PrintWindow could not be located in the dynamic link library USER32.dll.
Read moreHi there,
My antivirus is updated and after I scan no virus was found. This Error Goblin tells me that I might I have a virus. Does anyone have any idea about this Error Code: 0xe2 ? What could cause this error and why my antivirus didn’t find any virus ?
Thank you !
Error Goblin
Look up any Windows error code to find out what it actually means.
We also have an offline and portable version for Windows available for download.
Error Code: 0xe2
Description: This file contains a virus and cannot be opened. Due to the nature of this virus,...
Read moreHello there,
I have this error caused by Microsoft Forums and I don’t know how to fix this DLL issue. I searched on the Internet for download and didn’t find it. Also I installed a DLL fixer and I still have this error. Can anyone help me please to fix this? If I find this DLL file how I can install it?
Thank you!
bnbtfrontend
Component ‘FM20.DLL’ or one of its dependencies not correctly registered: a File is missing or invalid
OK
Read moreHello experts,
I made an update to my Acrobat Reader and when I opened a PDF file this error appeared. I reinstalled the Acrobat Reader and still I have this error. I don’t know what to do anymore and can anyone please help me to fix this? Why I have this error even after I reinstalled the Acrobat Reader?
Thanks!
AcroRd32.exe - Application Error
The exception unknown software exception (0xc0000710) occurred in
the application at location 0x77829f91.
Click on OK to terminate the program
OK
Read more
Hi experts,
While my PC was opening this error appeared on my desktop. I verified all my startup programs and the folder is empty. I made a small search on the Internet and nothing useful was found about this error. Does anyone have any idea about this error? How can I solve this, please help me!
Thanks!
nvxsync.exe - System Error
The program can’t start because OpenLDAP.dll is missing from your
computer. Try reinstalling the program to fix this problem.
OK
Read moreHi there,
Every time I run Paint Shop Pro this error with plug-in missing appears. I did not install any plug-in and it worked just fine until now. I have this error even after I reinstalled the Paint Shop. Can someone help me fixing this error message? Why I can’t get rid of this error?
Thank you!
Paint Shop Pro Photo
Unable to load the requested plug-in filter. The plug-in may not be installed properly or may be missing files. (Plugin: autint10.8bf)
OK
Read more
