Archive
Hi there,
I have this error from my new game that I have installed on my PC. Total Annihilation is giving me this error and I don’t know what it means. I have this error when I want to play online. I have a high speed Internet connection and this should not be a problem. Can anyone help me to fix this error ? What could be the problem.
Thank you !
Total Annihilation
Timed out while connecting to DirectPlay lobby!
OK
Read more
I installed Modern Warfare on my laptop today, but when I tried to play the game this error cut all my dreams of playing. I don’t know how can be solved this error, the only thing that I did was to reinstall the game hoping to solve it, no chance. Is any expert online and can help me to fix this error? Can I prevent this happening in the future with other games?
Thank you!
iw4m.dat - Entry Point Not Found
The procedure entry point _BinkGetFrameBufferslnfotg@8 could not be located in the dynamic link library binkw32.dll,
OK
Read more
Hi there,
I tried to update my Axiom Pro Firmware 25 and this error ruined everything for me. I searched to make a download from different servers but nothing useful was found. I am new on Apple and I don’t have a big experience with this kind of errors. Please is anyone available to help fixing the mess I did?
Thank you!
Axiom Pro 25 Firmware Updater.app can’t be opened because It Is from an unidentified developer.
Axom Pro 25 Firmware Updater.app is on the disk image Axiom_Pro_25_Updater_OSX_1_0_1.dmg. Safari downloaded this disk image today at 10:25 AM from www.m-audio.com.
OK
Read more
I downloaded the latest version for my audio hardware and I have this error. I don’t know why is saying that I need the latest version since this is the only one that I found it. Can anyone help me to fix this? You know any other ways to download the latest version of drivers?
Thank you!
Mac OS Error (MotuAudioSystem Mas CoreAudio error epon, DevSet:StartAudioCallbacks [1852 797029: 1])
Hardware Setup Studio Setup
Read more
Thank you!
Audio System Error
Cannot write to speaker:
Java.lang.RuntimeException: wave out device stalled
OK
Read more
Hi experts,
Today I reinstalled my Windows 7 (x32) on my laptop and I have this error for the first time. I never had this error before reinstalling my Windows and I to think that I might did something wrong in settings when the installer was running. Can anyone help me to fix this error? Why I have this error now and can this kind of errors be prevented in the future?
Thanks!
The ASlO sample rate is not supported by one of the USB interfaces! Please check your sync settings in the Control Panel.
OK
Read more
I downloaded Krasha application to generate some errors and crashes but it seems like I have this error when I try to open Krasha application. Now I don’t know if this is a process of the application or the Krasha have some errors. Does anyone have any idea about this ? What is the real problem or is this really a problem ?
Thank you !
Sorry!
The application Krasha (process org.krasha) has stopped unexpectedly. Please try again.
Force Close.
Read more
I was reading the new on the internet when suddenly this error message box appeared and closed everything that was open. My PC worked fine for a while when this error appeared again. I am afraid that my Windows will crash totally, so can anyone help me to fix this error please? You know what might causing this?
Thanks!
STacSV Module stopped working and was closed
A problem caused the application to stop working correctly. Windows will notify you if a solution is available.
Close
Read more
I have this error from Android SDK Manager and I don’t know how to solve it. I tried to run it many times and the same error appeared. Also I made a forced download with no result. Can anyone help me to fix this one please ? What this error means ?
Thank you !
Refresh Sources
Fetching https://dl-ssl.google.com/android/repository.xml
Failed to fetch URL https://dl-ssl.google.com/android/repository.xml, reason: HTTP SSL error. You might to force download through HTTP in the settings.
Close
Read more
Hello there,
Even I have my PC up to date, all the programs are up to date and the Flash Player also is updated I still have this error on GameRanger. I don’t know what to do anymore and how can this error be solved. Does anyone have a solution for this error please ?
Thanks !
GameRanger: Flash Player Needs Updating
Your Adobe Flash Player web plug-in is Version 1 and needs to be updated to the latest version for security fixes.
Download and run the update from Adobe’s site.
OK
Read more
