Archive
Hi there,
I can’t install Skype on my iPod because of this error. I don’t know how can this be solved or if this Skype version is OK for my iPod. I want to install it because all my friends are using Skype and I want to be close to them. Please help me to fix this error. Why I have difficulties to install it ?
Thank you!
iTunes
The app “Skype” was not installed on the iPod “GirlGames99.com”
because an unknown error occurred (0xE8008001).
OK
Read more
Hi there,
I have this error when I want to install India Map 2013 for my City Navigator. The installer is OK, the version of the software is OK, and the only problem is when I have to accept the terms of the license agreement. I choose I agree but when I click next this error appears. Can anyone help me to fix this error? Why I have this error? All my friend have the same right version as me and they don’t have a problem…
Thank you!
India Map 2013.10 Updater
Can’t find the unlock record
OK
Read more
For a while it seems like I have some DLL file errors. For two days it started to appear on my windows startup and is. Nothing happens when I OK them but still. Can anyone help me please to fix these errors? Why I have this errors and should I reinstall my Windows?
Thanks!
RunDLL
Error loading C:Windowssystem32wvUlIYrO.dll
The specified module could not be found.
OK
RunDLL
Error loading E:Program Files (Vista)Movie Makerwmm2clip.dll
OK
Read more
This is the note with error that I have when I want to install some new maps on my laptop. I want to install some new maps on GPS also I am thinking maybe would be good to test them first on my laptop. I am blocked with both processes and no idea how can this note be solved. Techyv experts can you help me to fix this one? Should I install the new maps directly on my GPS?
Thanks!
Note
There was an error installing your maps. Please try again. If problems continue, please contact...
Read more
Microsoft Visual Studio gives me this error when I want to install it. I have the right version for my PC and it seems like it won’t work at all. Can someone help me to install and make the right settings for this software? Why is not working for me?
Thank you!
This server version is not supported. You must have Microsoft SQL Server 2005 Beta 2 or later.
OK
Read more
I have downloaded the Pro Tools LE compatible with my Windows 7 and also I have downloaded a version compatible with Windows XP. None of this versions wants to work, and I don’t have any solution for this. Please make me to understand why none of them are compatible with Windows 7, especially the Windows 7 version? How can I install this?
Thanks!
Pro Tools LE – InstalIShield Wizard
Error
The current Microsoft Windows version does not support this operation. occurred in Copylnf.cpp at line number.383 Other Error.1O Internal Operation :200
OK
Read more
I have downloaded and installed this software, trial version from official website and I have this error when I want to install. I tried many times to install it and I used different tools but no success. I really need to try this software so please can anyone help me to fix this error? Why I have it? I will have it even when I will buy the full version of software?
Thanks!
Avid Media Composer
Unable to write to file “/Volumes/PC/Avid MediaFiles/MXF/1/Creating/Creating4”.
Exception: MXFDomain::WriteindexTable - Failed to write index table to file
OK
Read more
Hi there,
I have this error in Ubuntu when I want to connect my Android device to my laptop. On my PC with Windows 7 I don’t have any problem connecting the same Android device. I start to believe that I have a problem with my laptop. How can I connect my Android device to my laptop without getting this error?
Thank you!
Unable to mount Android
Error initialising camera: -53: Could not claim the USB device
OK
Read more
My printer is not working anymore, after a long 3 years life without an error this is the first one that my printer gives to me and I don’t know how this can be solved. Is there a solution for this error? Should I buy a new printer?
Thank you!
Connect to Printer
Windows cannot connect to the printer. Operation could not be completed (error 0x00000035).
OK
Read more
Hello experts,
When I was trying to open HP ProLiant Integrated Management I got this error message box. I was a little bit surprised because is the first error that I have after a while. Everything worked fine and can anyone help me to fix this? Should I be worried that this error appeared?
Thanks!
No System Management driver is loaded.
OK
Read more
