Archive
I just installed a new game on my laptop with Windows 7 and when I tried to open it this System Error window appeared. I have uninstalled the game, rebooted the laptop and install it again, but I couldn’t get rid of this problem. I really want to make this game to work so is there anyone who can help me to run this game and tell me why I have this error and how can I solve it.
Thank you!
The program can’t start because xmogrt.dll is missing from your
computer. Try reinstalling the program...
Read more
On startup of my Windows XP this error message appeared. If I click OK my taskbar is not loading and my screen freezes. After a reset this error appear again, when I click Cancel everything works just fine. I want to get rid of this error but I don’t know how. Please, is there anyone who can help me fixing this error? What is causing this application error?
Thank you!
The instruction at ‘0x008637ae” referenced memory at “0x009e20b8”. The memory could not be “read”.
Click on OK to terminate the program
Click on CANCEL to debug the...
Read more
Hi there,
After installation of Microsoft visual studio on my PC with Windows XP (32) I got this error message. My friend too, installed this program, but is running without error. I don’t really know what is this error and how can I solve this. Please help me to solve this problem with the program and tell me why I have this error message?
Thanks!
Microsoft Visual Studio
A reference to ‘OutOfProcServer’ could not be added.
The ActiveX type library D:DatenVSone 2007UACSamplesConsumeMyElevatedCOMOutOfProcServerbinD ebugoutofprocserver.tlb was exported from a NET assembly and cannot be added as a reference,
Add a reference...
Read more
I have this error message box caused I think by Minecraft which is the latest game and program installed on my PC. Also I have update Microsoft FrameNetwork hoping that will solve this error, it doesn’t work and I don’t know what to do anymore. Can anyone help me to fix this error? Is Minecraft causing this?
Thanks!
Java Virtual Machine Launcher
Error: opening registry key ‘SoltwareJavasoftJava Runtime
Environment’
OK
Read more
Hi there,
This PowerBASIC program gives me this error after I installed it. I don’t know how to read an error so I don’t know how to solve it. Is there anyone who can help me to fix this error and run this program without any error please?
Thank you!
PowerBASIC
C:WindowsWinSxSx86_microsoft.windows.gdiplus_6595b64144ccf1df_1.1.76011 I .7601. 17825jione32d273598668a06bGDIPLUS.DLL
OK
Read more
I have installed on my PC Grand Theft Auto IV and when I want to play the game this error appears. I did some researches on the Internet and I tried some of their solution but nothing worked. A friend of mine recommended this website and I would like to get some help from you. Please can anyone help me to fix this error? What could cause this one?
Thanks experts!
Exception EFCreateError in module DSOUND.dll at 000116C5.
Cannot create file “C:Program FilesGrand Theft Auto IV – Episodes from Liberty Cityasilog.txt”. Access is denied.
Read more
Hi there,
This error with network rendering in 3ds max and I don’t know what is happening with my program. It worked just fine hours ago and it came up with this error. Does anyone have any idea why I have this error? How can this be solved?
Thank you!
Network Rendering
Cannot network render? Backburner not found or not installed. Verify that the path to backburner is set in the Windows path environment variable or that backburner is actually installed on this system.
OK
Read more
Hi there,
I have this error when I want to open 3ds max. I reinstalled the program again because I had to reinstall my Windows XP. My previous Windows were 7 and the program worked just fine, but I don’t like the OS. Can anyone help me to run this program on Windows XP ?  Should I install Windows 7 again?
Thanks experts!
3dsmax.exe - Unable To Locate Component
This application has failed to start because AcGe16.dll was not...
Read more
I have updated my Windows 7 and installed Visual Studio 2010. I rebooted my PC because the program required one and on startup this error message box showed up on my desktop. What is this error with DLL? Can anyone help me to fix this?
Thank you!
Replsync.dll- DLL. Load Error
Cannot load resource dll: REPLRES.RLL
The specified module could not be found.
OK
Read more
Hi there,
This Connection Error appears when I want to connect MyChart to the Internet. I did a fresh install and is not working at all. When I have installed the app first time it worked just fine for 2-3 weeks. Can anyone help me to fix this error of my app ?
Thank you !
Connection Error
MyChart cannot obtain a connection to the server even though you have an Internet connection. Do you wish to send a report on this error? The report will not contain any personal information
Send
Do Not Send
Read more
