Archive
Hi experts,
I had to replace my iPhone charger because the old one “burned” out. It seems like the new accessory is not certified. I bought it from an Apple provider and I don’t know why is not working. I have this error because some settings are wrong ? Should I change the charger ?
Thank you !
This cable or accessory is not certified and may not work reliably with this iPhone.
Read more
I am not able to work in SQL Server Integration Service. Please find below error message.
Error Message
TITLE: Microsoft Visual Studio
An error prevented the view from loading.
ADDITIONAL INFORMATION:
The specified module could not be found. (Exception from HRESULT: 0x8007007E) (System.Windows.Forms)
BUTTONS:
OK
Read more
This No Network error appears every time I want to play this game in multiplayer mode. Is not working with Wi-Fi and Bluetooth. My Internet connection is OK the Bluetooth is working properly and still I have this one. Does anyone have any idea how can this be solved ? What should I do ?
Thanks !
No Network
To use multiplayer, please enable Bluetooth or Wi-Fi in your device’s Settings.
OK
Read more
Hi there,
I use my home Wi-Fi network to use FaceTime but I can’t connect to the network. This message appears and all the settings are OK, the only problem with my iPhone is that I can’t connect to my wireless network. My Internet connections is working just fine. Can anyone help me to fix this problem please ?
Thank you !
No Network Connection
Connect to a Wi-Fi network or cellular data to use FaceTime
Wi-Fi Settings
Cellular Settings
OK
Read more
I got an error on opening Twitter with Chrome. It seems like an issue with the certificate. Because of this, I was unable to launch Twitter for almost three days now. The error is stating:
SSL Error: Cannot connect to the real twitter.com. Something is currently interfering with your secure connection to twitter.com.
Try to reload this page in a few minutes or after switching to a new network. If you have recently connected to a new Wi-Fi network, finish logging in before reloading.
If you were to visit twitter.com right now, you might share private information with an...
Read more
I have edited some files and also created new ones for a server of Counter Strike. Today when I tried to open the new files and save them this ERROR popped up. I think I might lost all the work I have done and I would like to know if there is a solution for this error? What are the chances that all files are lost? Thank you experts!
ERROR
SaveDevice_PC-TempSaveGame:cannot open file for saving
EXIT
Read more
During the install of Omnivex Display 3 Player this error message box appeared and the installation was closed. I tried to run an installer downloaded from different servers and nothing seems like to work. Can you experts provide me a good installer for this program ? Why the installer from the official website is not working ?
Thank you !
Omnivex Display 3 Player Installer Information
Error 1904.Module
C:WindowsSysWOW64VideoCapX.ocx failed to register. HRESULT. Contact your support personnel.
OK
Read more
Hi there,
Maxthon gives me error when I want to open it on my Windows 7 (x64). I have this error after I did the updates to my Windows and it worked fine before. Now I can’t solve this error and I tried some tricks that a friend told me. Does anyone can tell me how can I solve this puzzle?
Thanks!
Maxthon
An error has occurred. Please send the bug report to us after browser restart.
Fault address: 6EB506F9 01:0009F6Fg
C:WindowsSysWOW64mshtml.dll
OK
Read more
Guys I have this error when I want to open a PowerPoint with Microsoft Office PowerPoint Viewer. Is this compatibility issue on my PC? I have this PowerPoint from college and on the teacher PC this viewer worked just fine. Can anyone tell me how can I open this PowerPoint document? Can it be opened without installing Microsoft Office?
Thank you!
This file requires the Compatibility Pack for the 2007 Office system to view its contents.
OK
Read more
Hi experts,
Even I have install SQL Server 2005 on my PC I still have this error. I don’t understand why because I meet all the requirements to run this program.
 Anyone knows why? What might be the problem and how can I solve it please?
Thank you!
Microsoft Dynamics AX Setup
You must install SQL Server 2005 Analysis Services with Service Pack 2 or higher before installing the Analysis extensions.
OK
Read more
