Archive
Despite numerous attempts I cannot download apache open office I always receive an International error code 2908 (F9CA2E00-7476-DD4D-8C20-223A2A9F8981
Read moreHi there,
This is the error when I want to test my Interne speed and I don’t know what is wrong. I ran the test many time and the result was the same. Can anyone tell me is there a problem with my Internet connections or the program have some errors ?
Thanks !
DARTest: In-App View
Caught ‘bootstrap_impl’: Failed type check: line 1193 pos 14: type ‘LinkedHashMapImplementation’ is not assignable to type ‘HipsterModel’ of ‘value’. Took 13 ms
Read moreHi there,
I don’t know what this means but I have this error with Invalid License to all my apps. I don’t know what happened and who is causing this. I am scared because I might lose everything on iPad. Can anyone come with a solution for my problem please ? What is happening ?
Thanks experts !
Invalid License
This forum is currently not available on this app. Please contact the forum administrator.
OK
Read moreHello,
My Ableton had a serious error today and now is not working at all. At the beginning I thought that might be an usual crash but now is not working at all, even after a fresh install. I don’t know how to solve it and I hope that someone will help to fix this please.
Thank you experts !
Ableton Live
A serious program error has occurred.
This application will shut down after this message box is closed.
Current schema has changed
OK
Read moreHi experts,
During the shutting down my PC this error message appears and I have to click OK every time to continue turning off. Is annoying because I have to stay to my PC until is off and I want to get rid of this error. Please can anyone help me fixing this error ? If is possible please tell how can this error be prevented in the future.
Thanks experts!
Application Error
Exception EOleSysError in module Skype.exe at 0013EF05. The keyset is not defined.
OK
Read moreHello,
Every time I want to export some files using Eclipse this message appears. I never experienced such error before and I don’t know how to fix this. Can an expert tell me how to fix this error? What is causing this and how can I avoid this kind of errors in the future? Thank you!
Problem Occurred
‘Android Release Export’ has encountered a problem.
Failed to add /var/folders/9f/q_v2pxw22g7h_bd9p0gxfp80000gn/T/android_4696010078183700092.dex
Details >> OK
Read moreHello,
This morning Sibelius 7 gave to me this error when I tried to open the program. Is for the first time when this program gives any error and now is not working anymore. Anyone have a solution for this error ? How can I solve this ?
Thanks !
Sibelius 7
Unspecified error (1)
OK
Read moreHello,
I finished to install League of Legends and when I tried to play the game this error message box appeared and killed the mood. I didn’t find any answer on the official LOL website and I thought I should try in here. Is there anyone that can help me to fix this ? What should I do so I can play the game ?
Thank you !
LOLRecorder.exe - .Net Framework Initialization Error
Please set registry key
HKlMSoftwareMicrosoft.NET FrameworkInstallRoot to point to the .NET Framework install location.
OK
Read moreHi there,
I have this document which a project for college and I cannot open it. It seems like is broken only on my MAC. The document is OK on any other devices and I start to think that might be an error with my MAC. Can anybody tell me what is this all about ? How can I open this document on my MAC ?
Thanks !
Das Dokument “/Volumes/targetpartition/new recover/Recovered Files/Scan 5/Found Files/Orphans Folder/Folder 10143/dtsa004.als” ist defect.
[Unknown Compound Stream Type]
OK
Read moreHi,
Today I experienced an unpleasant error and I stuck with it. No idea why and how can this be solved. I have no idea what is causing it since yesterday all worked just fine. Is anyone there that might have a solution for my error ? Can’t this error be prevented in the future ?
Thank you !
Soldat
Access violation at address 0051B7B4 in module ‘Soldat.exe’. Write of address 00004B70.
OK
Read more
