Archive
When I try to set up an application in windows operating, I ended up with an error message. The problem triggered when I try to set up, the setup cannot write the value to the register key. The error says that I need to verify that I have sufficient permissions to access the registry. Please help me to fix the problem. Thanks.
Setup
Error 1406: Setup cannot write the value to the registry key SoftwareMicrosoftWindowsCurrentVersionExplorerBrpwser Helper Objects{D0498E0A-45B7-42AE-A9AA-ABA463DBD3BF}. Verify that you have sufficient permissions to access the registry or contact Microsoft Product Support Service (PSS) for...
Read more
Hello Pro,
The installation went pretty well and good without experiencing any problem. However, the real problem triggered at the end of the setup. Why I am getting this error message? I tried to run the setup several times but nothing happened. Someone could help me to solve this error. Thanks for your help.
A required component for interacting with Outlook is not available. Please run setup.exe.
Read more
Hi Pro,
I am getting a weird error message while I am working with Access. I got this error message when I try to make a new Custom Web App in Access. I do not have much information about this error. Google has not helped me to find the solution. Please assist me solve this problem. Thanks in advance.
Microsoft Access
An error has occurred.
TECHNICAL DETAILS
Correlation ID: 65e8089c-c15a-209b-7b21-9a45a13f1e1b
Date and Time: 3/18/2013   12:14:54...
Read more
Hello tech people,
I encountered a problem while working with the Microsoft Visio 2013 application. While working it throws an error message ‘you are attempting to open a file type that has been blocked by your file Block settings in the Trust Center’. I am not able to proceed with the help it provides. How do I fix the issue? Any one facing the same error problem please help me to fix it. Thanks.
Microsoft Visio
You are attempting to open a file type (Vision 2003-2010 Binary Drawings, Templates and Stencils) that has been blocked by...
Read more
Hi tech guys,
Lync download and launch went pretty well and good without creating any problem in the client environment. However, the problem triggered when they try to login, an error message pops up. The error message states ‘the specified address is not recognized or does not exist’. This error message is not bothering in any manner, it just pop up. How do I get rid of this error message? Please help.
Lync
The specified address is not...
Read more
Hey,
Friends when I try to install Microsoft Office for the first time in the computer I ended up with an error message. The download went pretty well and good but the real problem triggered when I setup. I have Windows operating system 64-bit version. I do not have any other version in the computer. Please help me to fix the error.
Microsoft Setup Bootstrapper
Microsoft Setup Bootstrapper has stopped working
A problem caused the program to stop working correctly. Windows will close the program and notify you if a solution is available.
Read more
Hello Experts,
When I try to install the Microsoft Office in the computer, I got a weird error message, which is completely new to me. I am not a technical person so finding some kind difficulty in solving this problem. I really do not understand the root cause of this issue. How to run the 32-bit set up to install office? Is there any alternate procedure to solve this error message? Please help. Thanks.
We can’t install the 64-bit version...
Read more
Hi Experts,
When I try to install Microsoft Office 2013 in the computer, I am getting a pop up message. This pop up error message blocks me from installing the Microsoft Office.  I tried the common methods like restarting and reinstalling but still I am getting this pop up error message repeatedly. For your information I have windows XP operating system, please help me fix the problem. Thanks a lot.
Error
The system cannot find the file specified.
Read more
Hello friends,
I have Microsoft Office in the computer, which was download, and installed from the authorized website. The software installed in the computer is licensed one but still I am getting an error message stating Microsoft Office cannot find your license for this application. I tried to restart the computer several times but no luck. Please help me resolve the error. Thanks.
Microsoft Office can’t find out license for this application. A repair attempt was unsuccessful or was cancelled. Microsoft Office will now exit.
Read more
Hi friends,
When I try to install the Microsoft office application for the first time in the computer, I ended up with an error message. For your information, I do not have any previous version of office in the computer. Why this is not allowing me to install Microsoft office in the computer?  I tried to install office several times but I am getting the same error message. Please help me, thanks.
Office
Something went wrong and we can’t sign you in right now.
Please try again later.
Read more
