Archive
My Internet connection is OK, I don’t have any error while surfing on the Internet and no lag but I have this error when I try to establish a connection with Exchange server. It worked just fine until now and I don’t know how to fix it. Can anyone help me please to solve this ?
Thank you !
ExFolders
An error while trying to establish a connection to the Exchange server.
Exception: The Active Directory user wasn’t found.
OK
Read more
Hello there,
I just installed the newest version of XML Tools for N++ and when I want to open N++ I have this error. With the previous version of XML Tools the program worked just fine. Can anyone help me please to run the new XML Tools ? Should I reinstall the previous version ?
Thanks !
XML Tools plugin
Error unable to register NS with prefix=”(null) and href=#########
OK
Read more
Today I made a full install of System Center Configuration Manager 2012 with all functions like Application Catalog. When I want to connect to the server I have this error and I don’t know how to solve. Does anyone have a solution for this error ? Why I cannot connect ?
Thank you experts !
Cannot connect to the application server.
The website cannot communicate with the server. This might be a temporary problem. Try again later if the problem has been corrected. If this problem continues, contact your help desk.
Back to Application Catalog
Back to My Application Requests
Read more
I tried to move from Exchange 2010 to Exchange 2003 and I have this error when I try to get Full Access manually. My friend did the same process and it worked just fine and never had any error. Can anyone help me please to skip this error ?
Thanks 1
Microsoft Exchange
Some controls are not valid. The Exchange Server is in an inconsistent state. Only disaster recovery mode is available. Please use Setup/mRecoverServer to recover this Exchange server.
OK
Read more
On my Event Properties I found this error and I think I got it when I tried to generate and offline address book. I think I’ve messed up a bit Microsoft Exchange and I don’t know what to do next. Is there an expert that can help me please ?
Thanks !
Event Properties – Event 9331, MSExchangeSA
OABGen encountered error 80004005 (internal ID 50103b7) accessing the public folder database while generating the offline list for address list ‘/’-Default Offline Address Book
Read more
I have this error when I want to uninstall Exchange Server and I can’t find a way to make. The Add/Remove Programs is not working because the same error appears. I don’t know how to get rid of this error so can anyone help me please to uninstall this properly ? What could be the problem ?
Thank you !
Completion
The following server roles have not been removed.
Elapsed time: 00:00:10
Setup was unable to uninstall the server role.
Error:
The following error was generated when “$error.Clear():uninstall-MsiPackage-PackagePath ($RoleInstallPath + “MailboxMSFTE.MSI”)-LogFile($RoleSetupLoggingPath+”InstallSearch.msilog”j” was run. “Couldn’t open package ‘C:Program FilesMicrosoftExchange ServerV14MailboxMSFTE.MSI’. Another version of...
Read more
Hi there,
This morning I had some errors with Outlook and I discovered that it was disconnected. Also I have checked Exchange Server and the Database it was not mounted. While I was trying to mount again the Database this error appeared and I am stuck with. Any solution for this error ? How can I solve this ?
Thank you !
Microsoft Exchange Error
Failed to mount database ‘Mailbox Database’.
Mailbox Database 0612536984
Failed
Error:
Couldn’t mount the database that you specified. Specified database: Mailbox Database; Error code:
An Active Manager operation failed. Error: The database action failed. Error: Operation failed with message:...
Read more
Hi there,
After I have created an active and available group and it was populated and properly configured with Mailbox server members this error appeared. I followed the same steps again and I still have this error. Can anyone tell me please what I did wrong ? Can you help me to make the right configurations ?
Thank you !
Add Mailbox Database Copy
Completion
The wizard could not complete. Click Finish to close this wizard.
Elapsed time: 00:00:00
Summary: 1 item(s), 0 succeeded, 1 failed.
Error
Registry key has subkeys and recursive removes are not supported by this method.
Warning:
An unexpected error has...
Read more
I have this error when I want to export my contact from Outlook in Exchange Server. I followed the steps that a friend of mine gives and he also did the same steps and it worked just fine. I think I missed something that causes this error. Can anyone help me please to fix this ? What I did wrong ?
Thanks !
Completion
Error:
Mailbox database “serverFirst Storage GroupMailbox Store (server)”doesn’t exist.
Click here for help…
Exchange Management Shell command attempted:
‘domaine.local/medewerkers/test’ /...
Read more
Hi there,
I ran a clean install of SharePoint Enterprise on my Windows XP SP1 and I think I’ve missed some important steps that caused this failure. Does anyone have a solution for this failure ? What did I miss and how can I repair it ?
Thank you !
Installation Rules
Setup is running rules to determine if the installation process will be blocked. For more information, click Help
SharePoint version requirement for PowerPivot for SharePoint-Failed
Read more
