Archive
While I was working in AutoCAD suddenly I had this error without a reason. Is the first error that AutoCAD gives and after I clicked OK the program closed. I started the program again and it worked. The problem is that I have this error more often. Any solution for this error ? What is causing this ?
Thanks !
Unhandled Access Violation Reading 0xffffffff Exception at 1a06063h.
Read moreHi,
Recently I have installed AutoCAD 2010 on my Windows 7 (x32) and I have this error when I want to draw something or I open some simple functions. When I click OK my PC freezes and I have to reset it. Can anyone help me please to fix this error ? What is wrong with AutoCAD ?
Thanks !
FATAL ERROR: Unhandled Access Violation Reading 0X01ff Exception at 5c554951h
Read moreHi,
I have installed AutoCAD on my Windows Vista and after a while this kind of error started to appear. I don’t know how to solve it because is the first error that I have from AutoCAD and the program worked better on Windows XP. How can I solve this error ? Should I reinstall Windows XP ?
Thanks !
FATAL ERROR : Unhandled Access Violation Reading 0x0018 Exception at e0511224h
Read moreHello,
This is the problem. I have checked the compatibility on the website and the system requirements. I have the program compatible with Windows 7 (x86) and I meet all the system requirements. Still I have this error and I am a bit amazed. Does anyone have a solution for this error ? How can be solved ?
Thank you experts !
Setup initialization-Autodesk Autocad 2014
Operating System Unsupported
You cannot install this product on the current operating system. Please read the system requirements for details.
System Requirements
OK
Read moreHello,
I don’t know why but I cannot make the updates. This is the error that I have and if I click Retry it appears again. Can anyone help me please to make the updates ? Why I did wrong and what caused this error ?
Thank you experts !
Autodesk® Vault Workgroup 2014 (Server)
Error 1328. Error applying patch to file C:Config.MsiPTE852.tmp. It has probably been updated by other means, and can no longer be modified by this patch. For more information contact your patch vendor.
Retry Cancel
Read moreHello,
While I was installing Autodesk Revit 2014 this network failure error appeared and stopped the installation. I have checked the Internet connection and is working just fine but I don’t know what caused this error. Does anyone know something about this error ? What is causing it ?
Thank you !
Install Error:
Network Failure
OK
Read moreHello,
I have this error and I did everything that I know to solve it. The reinstall is not helping, a custom install is not helping. The problem is when I click OK I can continue to work for a while but it appears again and it’s started to be very annoying. Does anyone have a solution for this error ? What should I do ?
Thank you !
FATAL ERROR: Security system (hardware lock or network license) is not functioning or is improperly installed.
Read moreHello,
Today I’ve noticed that the Application Event Log on one of my Exchange 2010 Mailbox Servers is full with this kind of errors. I don’t why and what is causing these errors so can anyone help me please to fix this ? What is causing this ?
Thank you !
Event Properties – Event 9875, MSExchangeIS Mailbox Store
Unexpected error “DOC_TOO_HUGE: There are not enough resources to process the document or row” occurred while indexing document.
Mailbox Database: DB022
Folder ID: d81-6618BDF535
Message ID: 1-20e66570
Document ID: 285786
Error Code: 0x8004364a
Read moreHi there,
This error appears every time when I want to send an e-mail. I don’t know what could be the problem about security and timed out session it couldn’t be a problem because I am not leaving the PC and then send an e-mail. Can anyone help me to fix this error ? What is causing this and what are the security reasons ?
Thank you !
Error
Your request couldn’t be completed.
This may have occurred for security reason or because your session timed out.
Close
Read moreHello,
This is the error when I want to sync my phone with my laptop. I tried many times and I’ve been waiting many hours, I did what the error said. I am a newbie with PCs and I cannot manage this kind of errors very well. Anyone have any solution for this ? What I did wrong ?
Thank you experts !
Error
Sorry! We’re having trouble processing your request right now. Please try again in a few minutes.
Close
Read more
