Archive
Hello Tech savvy,
I got this odd error message pop up window when I try to register the Crystal report ocx component in windows operating. I do not understand where I went wrong during the installation process. Please help. Hunting for solution, please help me. Your help is really great. Thanks.
RegSvr32
The module “c:windowssystem32crystl32.ocx” was loaded but the call to DllRegistrServer failed with the error code 0x8002801c
For more information about this problem, search online using the error code as a search term.
Read moreHi experts,
I got this weird error message when I try to use a Meeting Add-in for Lync 2010. I do not understand why I got this error message and why it happened. Do I need to reinstall the add-in again? Do I need to contact the administrator? Please suggest me some solution to fix the problem. Thanks a lot.
Microsoft Lync 2010
Unable to identify the calendar owner. Please contact your support team.
Read moreHi all,
I got this weird error message while I am working in an application. The error title is winlogon – Application error. It says that the memory could not be read. Please help me get rid of this problem. I am not getting any help from the error message. How do I debug the program? Please assist me to do so. Thanks.
Winlogon.exe – Application Error
The instruction at “0x01253ec0” referenced memory at “0xb5ffac01”. The memory could not be “read”.
Click on OK to terminate the program
Click on CANCEL to debug the program.
Read moreHello,
While working with Microsoft Dynamics NAV when I try to assign a Zetadocs ID I was stuck with a warning error message. The error says that your company has not been assigned a zetadocs ID. Please contact you administrator. How do I fix this error? Please help. Thanks a lot.
Error: your company has not been assigned a Zetadocs ID.
Please contact your administrator.
Page Edit – Sales Quote must close.
Read moreHello,
In Microsoft Dynamics when I try to use the GP utilities and when I try to initialize the conversion I got this error message. I do not understand the cause of this error. Why it is happening? Do I need to change the settings in configuration? Please help me to solve the problem. Thanks a lot.
Microsoft Dynamics GP Utilities
An unknown error occurred when initializing the conversion
Read more
Hi friends,
When I try to open the Microsoft System Attendant Mailbox, I ended up with an error message. It gives option for help but nothing worked out. Is there any configuration error? Do I need to change any settings? Please guide to fix the problem. Your help is really great. Thanks.
Cannot open mailbox/0-HEW Org/ou=Exchange
Administrative Group
(FYDIBOHF23SPDLT)/cn=Configuration/cn=Servers/cn=MBX1/cn= Microsoft System Attendant.
Read more
Hello Expert friends,
I am beginner in Microsoft SharePoint so working very hard to learn new concepts and techniques. While I am working in a project when I try to troubleshoot, I ended up with an error message. It says that it could not load the type. I am not aware what to do next to clear this error message. Please help. Thanks.
Error
Could not load type ‘Microsoft.AnalysisServices.SharePoint.Integration.ASLinkFilePage.
Troubleshoot issue with Microsoft SharePoint Foundation.
Correlation ID: 0c934c04-43e4-4b6d-b88e-226e9f4bbe5d
Date and Time: 3/20/2012 1: 37:16 AM
Read more
Hi Expert DBA’s,
In Microsoft SQL server Management Studio when I try to restore the server failed to do. The error says the database is in use, but no one is using the database. I do not understand where I went wrong. Please guide me or help me to trap the error. Your help is great. Thanks.
Microsoft SQL Server Management Studio
Restore failed for Server ‘1 1’. (Microsoft.SqlServer.Smo)
Additional Information:
System.Data.SqlClient.Eeclusive access could not be obtained because the database is in use. (Microsoft.SqlServer.Smo)
Read moreHi all,
When I try to connect to the SQL server 2008 R2, I ended up with an error message. The error says it cannot connect to local host and it says the login failed. However, I have the authority to access the server. In that case, why I got this error? Please help me to resolve this error and to find solutions. Thanks a lot.
Connect to Server
Cannot connect to localhost.
Additional information:
Login failed for user ‘ADTESTres’. (Microsoft SQL Server Error: 18456)
Read moreHello all,
I am getting a weird error message windows Script host. I am not aware of this error message in the experience. I am not a technical person so having a hard time with this error. I have attached the error image please do help me to resolve this error and find the solution. Thanks.
Windows script host.
Activating Windows server ( R ), ServerStandard edition (6a4bd364-4b60-4856-efb59d94348e)…
On a computer running Microsoft Windows non-core edition,...
Read more
