Archive
Hi there,
During the initiating phase of installing Infrastructure Design Suite Premium this error appeared and closed the install. I have the right and compatible installer and it should work. Any solution for this error ? Is there an error with the installer or with my PC ?
Thank you !
Autodesk Infrastructure Design Suite Premium 2014
The requested operation cannot be performed on a file with a user-mapped section open.
K:SetupReseval.msi
Read more
Today I bought a new PC so it’s clean with a good configuration. I’ve installed AutoCAD 2014 and when I want to open the program this error appears and closes the application. My VGA driver is up to date. Any solution for this error ? How can I solve this ?
Thank you !
AutoCAD LT- Missing or Corrupt Display Driver
A display driver file (.hdi) is missing or has been corrupted. The program will be closed. This problem may be caused by missing .hdi files in the following location:
Close
Read more
Hello Professionals,
I do not understand what I did in the system, whether there is the problem with the SharePoint or with the Internet Explorer. This error appeared when I am working in a project. The error says, “Call failed. Error: An unexpected ‘PrimitiveValue’ node was found when reading from the JSON reader. A ‘StartObject’ node was expected”. How do I solve this error? Please help. Thanks.
Message from webpage
Call failed. Error: An unexpected ‘PrimitiveValue’ node was found when reading from the JSON reader. A ‘StartObject’ node was expected.
Read more
When I am trying to connect my system through a MS Access tool to a Virtual Machine, which has SQL server installed. The error says the connection failed and it cannot generate SSPI context. How do I login in Server now? Please help me to establish a connection. Hunting for solution, please help me. Your help is great. Thanks.
Microsoft SQL Server Login
Connection failed:
SQL State: ‘S1000”
SQL Server Error:0
[Microsoft][ODBC SQL Server Driver] Cannot generate SSPL context.
Read more
Hi there,
This is the error that I have when I want to install AutoCAD 2014 on client and I don’t know how to repair this. I didn’t find the .tmp file to copy it manually and the installer is downloaded from an official website and it should work. Can anyone help me please to fix this error ?
Thank you !
The copy functions cannot be used. Failed to copy the following files:
\OdysseyautocadImg*.exe
To C:Users***AppDataLocalTemp_AI3DB4.tmp
OK
Read more
Hi Professionals,
I do not understand what I did in the system, whether there is the problem with the SharePoint or with the Internet Explorer. This error appeared when I am working in a project. The error says, “'Edit Document' Requires a Windows Share point Services-compatible application and Microsoft Internet Explorer 6.0 or higher”. How do I solve this error? Please help. Thanks.
‘Edit Document’ requires a Windows SharePoint Services-compatible application and Microsoft Internet Explorer 6.0 or greater.
Read more
Hi expert pro,
When I try to install the Microsoft Access database Engine, I ended up with an error message. For your information, I have Windows 2000 operating system 32-bit and 500 GB hard disk. Then I Microsoft Office package installed in the computer. I do not understand anything from the error message. Please guide me to find the solution. Thanks in advance.
Error in frmGenie: Sub cmdFileOpen_Click
Installing the Microsoft Access Database Engine is required to read Access/Excel 2007-2010 files and ODBC databases. Do you want to download and install this file? Clicking Yes launches...
Read more
Hello tech savvy,
When I try to access a webpage, I got this weird error message. The error says “error: error: Access is denied”. I did not get much information from the error message. How do I solve this error without any further information? Please help. Thanks for your help.
Message from webpage Error: Access is denied.
Read more
Hi tech savvy,
I got this weird error message while I attempt to change the state of virtual machine savtsfc01. The error says Microsoft Emulated IDE controller failed to power on with error general access denied error. I am not able to attach the IDE controller it throws an error. Do I need to change any security settings? Help please. Thanks.
Hyper-V Manager
An error occurred while attempting to change the state of virtual machine savtstfc01.
‘savtstfc01’ failed to start.
Microsoft Emulated IDE Controller (Instance ID
{83F8638B-8DCA-4152-9EDA-2CA8B33039B4}): Failed to power on with Error ‘General access denied error’
IDE/ATAPI: Could not...
Read more
Hi Experts,
In Microsoft SharePoint Project when I try to change a password and while working with a Report I got this error message. The error says that Access was denied by the external data source. The following connections failed to refresh. Friends suggest me some idea to overcome this error. Badly in help. Thanks.
Excel
Access was denied by the external data source. The following connections failed to refresh:
TfsOlapReport
Read more
