Archive
When I turned on my PC this error appeared on my desktop. I think it was created by my antivirus and I don’t know how to solve it. It appears every time I open my PC and the reinstall is not helping. Any solution for this error ? How can I solve this ?
Thank you !
Avgmgr.exe
Avgmgr.exe has encountered a problem and needs to close. We are sorry for the inconvenience.
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem.
We have...
Read more
On my laptop are created 2 users account and mine is the administrator. I have this error when I want to launh Lync. On the another account the program is working just great without an error and it doesn’t have admin rights. Can anyone help me please with this ? Why on my account with admin rights is not working ?
Thanks !
Lync has both per-user and per-machine instances installed. Click OK to remove the per-user installation.
OK Cancel
Read more
Hello there,
I have installed Lync Enterprise and SQL Developer Edition each on a virtual server and I have this error when I want to publish the topology. I don’t have big experience with this kind of errors so is there anyone who can help me please ? Why I cannot publish the topology ?
Thanks !
Publish Topology
Error
Topology Builder encountered an issue and cannot publish this topology.
The existing topology identifies*** as the Central Management Store, but the topology that you are trying to publish identifies**** as the Central Management Store. The Central Management Stores mush match...
Read more
Hi experts,
I cannot update my AVF antivirus anymore. This error appears every time and until now I didn’t find any solution. I have the original CD and a license for AVG and was expected to work without a problem. Any solution for this error ? Why I cannot update the AVG ?
Thanks !
Updating progress
Update failed.
General Error.
Close
Read more
Hi experts,
I have this long setup error when I want to install AVG anti-virus Free 2013. I don’t know why is not working since I have the installer from a trusted source and my PC is up to date. Any solution for this error ? What is causing this ?
Thank you !
AVG Antivirus FREE 2013
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2203.
Severity: Error
Error code: 0xC0070643.
Additional message: The removal of the product failed.
The installer has encountered an unexpected error installing this...
Read more
When I open my PC and try to start Lync I have this error and when I click OK the program is not starting. It worked just fine until now and I don’t remember to install anything or change some settings. Any solution ? How can I solve this error ?
Thank you !
Services
Windows could not start the Lync Server Front-End on. For more information, review the System Event Log. If this is a non-Microsoft service, contact the service vendor, and refer to service-specific error code -2164761487.
OK
Read more
While I was working on a project my laptop restarted. For the moment I thought that I can continue from the last save but this ERROR appeared and messed up my entire project. PLEASE help me to recover my project from the last save ! What should I do ?
Thank you experts !
Open Drawing – Damaged File
The drawing file was recovered.
Error were found and fixed in the drawing. Invalid data might have been changer or deleted, and some previously erased objects might have been restored.
Error found: 33
Error fixed: 33
Objects erased: 0
Review the information above...
Read more
I have this error since I have installed Windows Vsta (x32) on my PC and untill now I didn’t find any solution. Also I did a small search on the Internet I nothing useful was found. Can anyone help me with this ? Why I have this error during the install ?
Thank you !
Autodesk AutoCAD LT 2014
Warning 1964 Property’{9F4C2855-9F79-4839-A8D0-E1D42DE1D5F3},12’ for shortcut ‘Uninstall Toolink’ could not be set.
OK
Read more
Hello there,
I have a project that I started at college and I have to finish it at home. When I want to load the project on my laptop this error appears in AutoCAD 2010. The project was created in AutoCAD 2010 at college and I don’t think it might be an iconpatibility issue. Does anyone have any idea about this ?
Thanks !
AutoCAD Message
Customization file “FDMCAD.cutx” is an incompatible format and can not be overwritten.
OK
Read more
I did something wrong and I don’t know what. I have this error and I don’t know what is causing this and I have triple checked the project. I am stuck with this error and can anyone help me please to fix this ? What I did wrong ?
Thank you experts !
MAX Script Rollout Handler Extension
No”map” function for understand
OK
Read more
