Archive
Even if my PC and my drivers are updated I still have some error cause by the programs. This is one of them, it is caused by Kaspersy application and I don’t know anything about. Does anyone have a solution for this ? What is causing this ?
Thanks !
Avpui.exe – Application Error
The exception unknown software exception (0xe0434352) occurred in the application at location 0x74c82eec.
OK
Read more
Hi there,
In BitDefender Deployment Tool this error appears but sometimes I can skip this. I want to solve this because it started to be a bit annoying. Can anyone help me please ? What job has failed ?
Thank you !
The service cannot accept control message at this time.
Read more
When I start to prepare the forest of my Active Directory for Lync Server 2013 and follow the steps which worked very well for my friend, I have this error and nothing seems like to work. I did the same steps many time without a result. Does anyone have a solution for this error ? What did I missed ?
Thank you !
Prepare Forest Active Directory settings execution failed on an unrecoverable error. ForestPrepareTask execution failed on an unrecoverable error.
WARNING: Enable-CSAaForest encountered errors. Consult the log file for a detailed analysys, and ensure all errors(4) and...
Read more
Hi there,
I just bought a new license for Kaspersky and I have this error when I try to activate the license. This is the 3rd and the first two licenses were activated without a problem. Is there other way to activate this ? Why I can’t activate my antivirus ?
Thank you !
Cannot register activation code as a new code
Reasons and possible solutions
Read more
Hi there,
I try to install Lync 2010 RC on a machine in a domain that already runs OCS 2007 R2 and it gives me this error and warnings. I don’t know how to read this error and how can I solve this so is there an expert online that would like to help me please ?
Thank you !
TempInstall-CSadServerSchema-[2014_02_09][22_01_29].thml”
Creating new log file”C:UsersbaluilagAppDataLocalTempInstall-CSAdServerSchema-7b0835e1-0529-4b6e-9288-51af2aa00159.xml”.
Modify the Active Directory schema to support Lync Server 2013.
ServerSchemaPrepareTask execution failed on an unrecoverable error.
Creating new log file” C:UsersbaluilagAppDataLocalTempInstall-CSAdServerSchema-7b0835e1-0529-4b6e-9288-51af2aa00159.xml”.
WARNING: Install-CSAdServerSchema encountered errors. Consult the log file for a detailed analysis, and ensure all errors...
Read more
Hi there,
It seems like my installation file is corrupted and I have this error with the setup. I have the installer from the official website and it seems like they have some errors. Does anyone can help me please to fix this error ? What could be the problem ?
Thank you !
AVG Download Manager
Problem with setup!
The AVG Download Manager has encountered a problem. Click Retry button to start the download process again, or Cancel to quit. If you continue to see this message, please consult the product help for further information.
ErrorCode: 0xE001005C
Retry Cancel
Read more
What this error means ? I have installed this antivirus on my sister PC and now when I want to install it on my laptop I have this error. I use the same installer on my PC also and the host failed. I have downloaded the installer again and is not working. How can I solve this ?
Thank you !
AVG Antivirus FREE
Resolving host failed.
Severity: Error
Error code: 0xE001C008
Error message: Resolving host failed.
Addition message: An unexpected runtime error occurred.
Context: Initialization
Go online to learn more about this issue
Exit Save log
Read more
I am shocked because I paid a lot of money for the Autodesk and now I cannot activate the program. I think I might lost the license because I entered many times and all the time I had the same error. Any solution ? Is there another way to activate the program ?
Thanks !
Autodesk Licensing-Activation error
Registration- Activation Error (0015.111)
There is a problem with the activation code that you entered. Click one of the following links.
Read more
I have this error when I try to download an app from Store on my iPad. I have this error only for programs and not for games or music. My Internet connection is working OK and this started to appear from 3-4 days ago. Can anyone help me please to fix this ? What is wrong with my iPad ?
Tanks !
Error
*** could not be download due to an error. (403)
OK
Read more
I have this error when I want to transfer a call even the audio device is set up to accept calls. I don’t know how to make Lync to recognize my speakers and solve this ? Can anyone help me please to fix this ? Why this program gives me this error ?
Thank you !
Lync
Cannot complete the transfer.
Call was not transferred because **** does not have an audio device set up to accept calls.
Close
Read more
