Archive
I have a project in school and I need to convert some pictures to text and vice versa in Google Drive. However, I am unaware on how to do it properly. Can someone send me the methods on how to convert my pictures and text with Google Drive? Thanks.
Read moreGmail how can i get the Gtalk conversation stored in a thread now it shows as a single Hangout message for each message and i want it all from one person to be listed as one conversation
Read moreHi experts,
Is for the first time when I have this kind of error. I want to watch a video and I don’t think that it might be protected be something. How can I check if is protected in a way ? If is not what could be this problem ?
Thank you !
Display driver error
The video playback device does not support playback of protected content.
Read moreHi,
While the Camtasia was loading suddenly this error appeared and closed the program. Because of this crash Camtasia is not working at all. Please help me to fix this error without reinstalling the program. What was the cause of this error ?
Thanks !
Camtasia Studio
Camtasia Studio has stopped working
Windows is checking for a solution to the problem…
Cancel
Read moreHi there,
Recently I have experienced this kind of message. I didn’t allow for the permission because I was afraid that will harm my PC. Should I allow this ? Why it appears every time and is really necessary to give these permissions ?
Thank you !
“LogMeIn Plugin 1.0.0935” does not support the highest level of security for Safari plug-ins.
Websites using this plug-in may be able to access your personal documents and data.
When visiting other websites: Allow Always
Read moreHello experts,
I did everything the error said and nothing of these solutions work. Also I did a small research on the Internet for solution and nothing useful was found. Any solution for this ? How can I solve this and why none of these solution works ?
Thank you !
Camtasia Recored
A problem with your audio device will not allow the recording to start.
Try one of these: A different audio device by selecting another device within Recorded; Disable audio and just record the screen; Tweak the audio device settings-right-click the Volume button in your system tray and...
Read moreHi there,
When I tried to save a video file recorded with Camtasia this error appeared and I have lost the video. I tried to record another and the same error appeared. I cannot save any recordings that I make cause of this error. Any solution ? How can I fix this error ?
Thank you !
Camtasia Studio
Error: 0x80004005 has been returned when trying to write the file.
OK
Read moreHi,
After a scan of my PC while I was trying to load the scan log file this error appeared. I don’t know why but I could load it before. Can anyone please help me to load this ? What could be the problem ?
Thank you !
Bitdefender Total Security
Bitdefender has encountered an error while loading the scan log file.
OK
Read moreHi,
I cannot start to record my screen cause of this error. The program worked fine until now and also this is the first error that Camtasia gives. Since I never experienced such an error before I don’t know how to solve it so can anyone help me please to fix this one ?
Thanks !
Camtasia Recorder
Failed to start recording: : Temp Folder Uninitialized
OK
Read moreHi there,
LogMeIn gives me this error sometimes and at the most of the times it appears when I work a long time. I have reinstalled the program, upgraded, updated my drivers and nothing seems to work. Can anyone help me please to fix this error ? What is causing this ?
Thanks !
LogMeIn Control Panel
LogMeIn Control Panel has encountered a problem and needs to close. We are sorry for the inconvenience.
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem.
We have created an error...
Read more
