Archive
Hey guys,
When I use the program tinygrab version 1 I press the space bar to take a screenshot. After the green light goes off I assumed a tiny url would come up but nothing does. How do I access the URL?
Read moreHey everyone,
When I run hp remote diagnosis tool in firefox it will not display certain kinds of software. It will not display mainly the Microsoft office package. Is there any way to fix this?
Read more
Hey guys,
The Acer aspire one a0532h price is under $300, I see no other windows 6 cell battery for near that price.
I'm just wondering if it would run similar or if the extra money is worth it.
So is the ao532h all up a good deal?
Read moreHi,
I am using Windows 7 OS and having serious issues during the installing Sage Act Pro 2012. I had Sage Act Pro 2009 and it was working perfectly but why this is playing with me. I really need your help to resolve the following errors.
Sage ACT!
Unable to retrieve schema metadata
Hata
Object reference not set to an instance of an object.
Read more
I performed a Basic SharePoint Foundation (beta) using Win 2008 R2 x64 server and also installed Office 2010 on the same box. When I try to view a list in Data Sheet view, I get the following error message. Help me to fix this issue.
Message from webpage
The list cannot be displayed in Datasheet view for one or more of the following reasons:
-A datasheet component compatible with Microsoft SharePoint Foundation in not installed.
-Your Web Browser Does not support...
Read more
I’m having a problem opening Microsoft office word starter 2010. I get 4 different error messages given below. I tried my best as I can to remove these errors but could not. I need your help to fix this issue immediately.
Thanks in advance.
WINWORDC.EXE-Bad Image
C:/Program File (x86)/Microsoft Application Virtualization
Client/sentinel.dll is either not designed to run on Windows or it contains an error. Try installing the program again using the original installation media or contact you system administrator or...
Read more
Hi experts,
I have got a problem using Office 365 Preview whenever I try to login to an Office 365 “wave 15” tenant on a mobile device, I receive the following error message. I have tried it with different devices like android and I Pad but have the same problem. Help me to fix this issue.
Office 356 preview
Sorry! We can’t process your request right now.
The service is temporarily offline for scheduled maintenance or we’re investigating a problem. We’re...
Read more
I am getting the following application error which says the digital signature is not trusted. I tried reinstalled this application to resolve this problem but I could not fix this issue. I need your help to demolish this issue as soon as possible. I will be grateful to you.
The application “Group-Office Transfer Agent” From “office.agmonitoring.com’’ is requesting access to your computer.
The digital signature is not trusted. Java will not allow any access to...
Read more
I have successfully installed oracle Business intelligence for MS Office and setting up a connection I received login error message “Login Failed” when I entered the login details. The username and password are correct but still getting this error. How to remove this error? Any help would be appreciated.
Oracle BI
Login failed. Please check your username, password and Oracle BI Office server availability.
Read more
I am running Windows 8 OS and have successfully installed Share Point 2013 and Technology Configuration Wizard and failed after step 7/8 giving me the following error “Configuration Failed”. I want to resolve this error immediately.
Thanks in advance.
Once or more configuration settings failed. Completed configuration settings will not be rolled back. Resolve the problem and run this configuration wizard again. The following contains detailed information about failure:
Failed to create sample data.
An exception of type...
Read more
