Archive
I am trying to monitor the signal of a USB midi keyboard but the driver is not installed the keyboard is shown as an invalid USB device and I can’t start monitoring.  I had tried the free version on catching data during the enumeration stage but failed.  The monitor seems can start only after the USB device has been enumerated,  or it is a limitation of this free version? But isn't it the purpose of advanced USB Port monitor 6 to show what are the raw data on the port even without driver ? Is...
Read more
I have installed 2 drivers, MS and BS. But when using MS driver error occurs. InBluetoothDiscoveryDemo.exe, I have selected Microsoft radio and click "Disc. ON" button, then it shows this error. What's wrong? I really need your help to fix this issue.
Thanks in advance.
Error Message: Internal driver error.
Read more
I have downloaded and installed the missing drivers and as I check to
My computer>manage>device manager all of it was turn ok except my video controller...
I’ve search the internet looking for that driver but it always give me this file...
VGA_Intel_8.14.10.2230_W7x86_A.zip but then it my only problem is this. It keeps on displaying.... even I’ve downloaded several files of that from several websites. How can I fix this problem? Have any idea?
Thanks in advance.
Error Message: This computer does not meet the minimum requirements for installing the software.
Setup will exit.
Read more
During installation of a MuVo Vidz under Windows XP and when I have selected the option of USB Device Driver for installation, I have encountered this error message which I can’t resolve without expert’s advice. Any help would be really appreciated.
Error Message: Target system OS not supported.
Read more
I have received an error message while trying to establish a Bluetooth client. What is causing this error and how do I fix it? Any help would be appreciated. Thanks in advance.
Error Message: Error 42 occurred at Bluetooth Open Connection in Simple Bluetooth Client.vi
Possible reason(s):
LabVIEW: Generic error.
Read more
Hi experts,
I am a web developer writing my HTML in Text mate when I use the shortcut command+p to open the file in Google Chrome, the following error message appears. I want to remove this error so that I may open this file on the chrome browser. I cannot fix this issue without your suggestion.
Any Help on this matter. I am waiting for your advice.
Error Message: The document "index.html" could not be opened. Chrome Helper cannot open files in the "HTML text" format
Read more
I'm having trouble with a Briefcase folder. When I attempt to open the briefcase folder it gives me the following error message. "There is not enough memory to open the Briefcase database. Quit some files or programs, and then try again."
So, I followed the given instructions in the error box to resolve this matter but could not solve. Same error message appeared. I really need your suggestion to resolve this problem.
Thanks in advance.
Error Message: There is not enough memory to open the Briefcase database. Quit some files or programs, and then try again
Read more
I spent so much time looking for a solution to this problem and can't find any. I extremely need your help to resolve the following error message. Thanks in advance.
An error occurred while attempting to start the selected virtual machine(s).
‘Rumor’ failed to start.
Microsoft Virtual BIOS (Instance ID {AC6B8DC1-3257-4A70-B1B2-A9C9215659AD}): Failed to Power on with Error ‘Incorrect function’
‘Rumor’ failed to start. (Virtual machine ID 200E3E28-D805-43AD-7D83D4175A36)
‘Rumor’ Microsoft Virtual BIOS (Instance ID {AC6B8DC1-3257-4A70-B1B2-A9C9215659AD}): Failed to...
Read more
I get this error shown below, this is a known problem (and why hasn’t it been fixed, and why isn’t it clearly defined in the documentation? I am waiting for your suggestion to resolve this issue. Thanks.
Error Message: Database schema could not be retrieved for this connection. Please make sure the connection settings are correct and that the database is online.
The database has been placed in a state by user ‘Admin’ on machine ‘BIGGUY123’ that prevents it from being opened or locked.
Read more
I am having trouble using Windows Mail because it shows an error message "MSOE.DLL could not be loaded". I searched the solution from internet but I could not find. I want to start Windows Mail so help me to resolve this error. Any suggestions would be helpful.
Thanks in advance.
Error Message: Windows mail could not be started because MSOE.dll could not be loaded.
Read more
