Archive
I need to find electronic email fax server hardware to find a non-winmodem to set-up fax services under Windows 2008  R2.  It has to be a hardware based modem since 2 of them are going into the system.  I had read that 2 winmodems in one system will cause issues with fax services.   I need modem capable of handling 2 phone lines for two fax numbers.  I see a lot of modems out there, but none of them specify if they are hardware or software based. Thank you in advance.
Read more
I had scanned slides that results in tiff files approximately 500kb size.  I don’t know how if there is tif to JPEG convertor software other than deleting hundred slides and start all over.  I want to convert these files to decrease the file size.  But it would  be painstaking to have to do each individually in Photoshop.  Is there a program that will batch convert all of these files for me? So far searching Google hasn't helped me, and every time it looks like the said program will work on a Mac, it really won't  not unless it was...
Read more
Hi to all.
How am I going to initiate repair a file in red hat 6 for Linux 5  after I had installed Win XP? I have often faced a problem of repair file system when I change some settings In kernel. I had tried so many commands but I am not really sure if what command should I apply this time. I can only do single mode login since the run level 5 is always prompting me for a login name loop.
Please help me.
Read more
How can I recover printed files made and printed on my computer of previous version of an excel spreadsheet where changes were saved after I had accidentally deleted an important info?  I was working on an excel spreadsheet and had to leave my computer for some other important things to do.   I just saved all the documents I had been working so that I could shut down my computer. Today, I opened excel and when I opened the spreadsheet that I had been working on yesterday, I noticed that only the second page was saved and somehow the...
Read more
I am on SqueezeCenter 7.3.3 and loaded BBCiplayer 0.9m, I cannot open the mac play rtmp stream. Any help for this version. Also how do I know which version to upgrade to, in order to get this stream to work. . I used to have the link, but once I updated and reinstalled my media player (VCL player to stream and record), I lost the URL that I used to use. Can someone explain to me how I can use live streaming on the Mac?
Read more
I am still searching around to find a solution for getting this to work. I know most people may not use this but I thought I would throw the question out there. I use a sonic net net extender for work and is going fine in Windows 7.  But when I tried installing it on Windows 8 it doesn’t work and says that “A damaged version NetExtender was detected on your computer, please reinstall NetExtender to fix the problem”.  I had tried to put it in compatibility mode for Windows 7 and run as an admin to where the...
Read more
I have no idea on how to accomplish a project I am planning to create. Is it possible to use a date selecting box or use a date range to limit a combo? How can I accomplish this? I want to create a form so that I can see members who is no longer active in an event on a certain date range and select from it. Individual ID, Name of the member and position must be in one main table.
Further each table should contain multiple records of the same person during various ranges of dates. This will serve...
Read more
I have a problem now with my photoshop extended trial.  When I open 3ds file in photoshop cs6, it shows the object without any texture.  When also opening the file I have an error message saying “could not complete your request because there are too many files open.  Try closing some windows and try again.  My system is Win 7  64bit; Intel i7-2760QM @ 2.4 GHz; 15 GB ram; Nvidia GTX 560M.  So the error message doesn’t apply as I haven’t experienced chugging when files were open as my system is relatively fast.            ...
Read more
I have a task list associated with workflow.  I need to start daily weekly workflow and send mails daily, still the status of the task is equal to closed in sharepoint2010.  Is there a way to set up a workflow to send out an email with a daily weekly workflow template of activities that were completed for the day/week?  We do have views that show the day, and week and you can export them to excel, but I was hoping there was an access to do this automatically.  We get emails during the day about creating activities completed, but...
Read more
Hi. I am a new convert to the Mac world, my son and some friends are avid Mac users. I have had my iMac almost a year, just after my PC blew up! Everything downloaded was fine with no asking for passwords or codes. But, the error message says it won't install Print Shop without Art CD.   Then when I try installing the print shop art CD it says application not found. Please post if I have to burn these onto a CD first or not.  I do not want to sound like a complainer, but why is...
Read more
