Archive
I am experiencing problems when connecting to servers via SSH. This error message shows. What to do? Provide me the proper way to resolve this issue. Thanks in advance.
Couldn’t agree a client-to-server cipher (available: ase128-Ctr, aes256-Ctr, arcfour256, arcfour)
PuTTY Fatal Error
OK
Read more
I am trying to launch the remote control with TightVNC. When I attempt to do this I get the following error message which is very irritating. I can't take the control of the remote host. What can I do? Any help would be really appreciated. Thanks in advance.
ReadExact : SocketIPv4 error while reading
OK
Read more
VNC didn’t work and I am receiving the following error. How can I fix it? Can you provide the proper solution to resolve this issue? I extremely need your help. Any help would be appreciated. Thanks in advance.
.Unsupported protocol: RFB 004.00
Unsupported protocol: RFB 004.001
                                OK
Read more
I have just downloaded and built (successfully) 1.4.2. I got an error message when I execute resultant Wireshark. Can you provide a solution to resolve this issue? Assistance on how to fix this issue would be appreciated. Thanks.
Child dumpcamp process died: Exception 0×c0000135
OK
Read more
I have encountered this error in Wireshark. I get this error while opening the Wireshark. If I choose to ignore the error and to move on, the interfaces will not be available. Hence, it doesn’t allow capturing. Any help would be really appreciated. Thanks in advance.
Wireshark The NPF driver isn’t running
Wireshark
The NPF driver isn’t running. You may have trouble
Capturing or listing interfaces.
Don’t show this message again.
OK
Read more
I get the following error message when I click on the sound in the sound pool then the program freezes and after a few seconds an error message appears. I have checked the settings to resolve this problem but is annoying to me. How can I fix this issue? Help me. Thanks.
MAGIX Music Maker DirectSound Error DirectSound Create failed
MAGIX Music Maker
DirectSound Error:
OK
Read more
I want to connect fitz 6544 to my Home PC from work but I can’t install any software from there.
I am using the router, which have set up port forwarding. When I try to connect through my home LAN from another PC then I get the following error message. Any help would be appreciated. Thanks.
Error: Framebugger update rectangle too large
Pc3 ( 192.168.1.205)
Error: Framebugger update rectangle too large: 0×0 at (63972,36733)
Java Applet Window
Read more
I am getting the following error message using LogMeIn Hamachi which says “Failed to connect to the engine. How can I fix this error? Can you provide me the best solution so that I may start the engine? Thanks in advance.
LogMeIn Hamachi Failed to connect to the engine.
LogMeIn Hamachi
OK
Read more
On starting the LivePC from the player, I was prompted with the following error. The error prevents the VMware player from launching. I really need your help so please provide me the step by step solution. I would be really grateful.
Error while opening the virtual machine: A file access error occurred on the host or guest operating system.
VMware Player
operating system.
OK
Read more
Hi experts,
Recently, I have installed and ran 3Dmark vantage on my new updated system. When I did this to the CPU test the system crashed to a blue screen. These are my specs.
CPU 4004.5MHZ
QPI LINK 3603.35mhz
Multiplier 20.00
BCLK 200.20mhz
I set my system to stock clocks and ran the 3DMark Vantage CPU test again. I get a black screen and then an error message on the desktop (Win 7 64 bit RC). Please help with my Core i7 3DMark Vantage. Thanks.
ID3D10Device::CreatePixelShader failed: An invalid parameter was passed to the returning function (E_INVALIDARG)
Eva
thread_4:
affinity: 255
ID3D10Device::CreatePixelShader failed:...
Read more
