Archive
Acronis true image wd edition - won't resize from 900mg to 2000mg. Any help would be really appreciated. The error shows failed to move the selected data. Thanks in advance.
Failed to move the selected date
Error
Failed to move the selected date. Make sure that your
new hard drive is not smaller than your old one and
partitions do not contain errors. You can check for
The errors and correct them using a special utility.
OK
Read more
I have been trying to sync my files to an SSH machine (Solaris 11) from a Windows 7 box, keep receiving the error “Connection Failed: Algorithm fails”. I am capable to make a connection with psftp.exe (putty sftp) so the connection (firewall) is fine, just can’t get I worked.
Anybody some tips?
Duplicati Connection Failed: Algorithm negotiation fail
Duplicati
OK
Read more
Today, I downloaded the version of the Revo and then I uninstalled this version but I received the following error message when I attempted to reinstall the first version. Now I really need your help to resolve this error message. Any help would be really appreciated. Thanks.
Install Error Error starting service
Install Error
Error starting service (“C:WINDOWSsystem32REGSVR32.EXE”/s “C:Program FileSUPERAnitSpywarSASWINLO.DLL), aborting installation.
OK
Read more
I got an error message using BGInfo and let me know how to resolve this error? Is there any way to fix this issue? Please provide me the proper solution. Thanks in advance.
BGInfo Error importing settings from ‘c:prora~1BgInbginfo.bgi’
BGInfo
OK
Read more
I am getting error 1077 when I try to set the Selection Mode of a Listbox with a Property Node. The following error message irritates me every time. How can I fix this error? Provide any clue step by step. Any idea would be appreciated. Thanks.
Error 1077 occurred at Property Node (arg 1) in Untitled 12
Untitled 12
Possible reason(s):
LabVIEW: Invalid property value.
Property Name: Selection Mode
Continue Stop
Read more
Hello experts,
I am using Windows 7 64-bit Operating System and recently, I downloaded Autodesk Revit Architecture 2013 and 3D Max and installed it but after some time it displayed the following error message. I reinstalled the program so that I may fix this issue but the same error appeared. How can I fix this error? Is there any way to resolve this issue? Any help would be really appreciated. Thanks in advance.
Error 1402.Could not open key
Error 1402.Could not open key:
Read more
I have a problem while HijackThis Cannot Write to Hosts File and displays the following error message. I searched for it from the internet to resolve this issue but could not find any solution. Can you provide me proper solution? Any idea would be appreciated. Thanks.
The hosts file is locked for reading and cannot be edited.
HijackThis
Make sure you have privileges to modify the hosts file and no program
Is protecting it against changes.
OK
Read more
Someone used my laptop and downloaded mp3codec.exe and installed it after that I have been getting error messages like this whenever I try to move from one document to another in explorer what to do now?
I am using Windows Vista Operating System on my laptop and recently I downloaded mp3codec.exe and installed it. After the installation process I encountered the following error message. This shows the critical error on the screen and difficult to interpret the error message. How can I avoid this annoying issue even I have installed a protection software. Please suggest me any idea to fix...
Read more
I installed autodesk_revit_archotecture_2013-64xupdate1.exe on my computer and it worked fine. My co-worker got an error message when he tried to install the same update. What could be the reason? How can I resolve this problem? Any help would be really appreciated.
Thanks in advance.
Update Release could not be installed because the expected Autodesk product could not be located
Installation Error
The Update Release could not be installed because the expected
Autodesk product could not be located on your computer.
Make sure that you are using the correct Update Release for the
Product.
        OK
Read more
Sometimes when I start the application appears this error. I just close the application and run again that works well. What to do to avoid this error? Any help would be really appreciated. Thanks in advance.
Access violation at address 00404D14 in module ‘dc - unlocker2client.exe’. Read of address 0D353724.
OK
Read more
