Archive
I am getting an error message during the installation of Avira Antivirus Personal. I uninstalled the program and again installed the Antivirus but the same error message appeared. Can anyone provide me the solution to fix this error?
I would be really grateful to you.
The installation of the LSP failed. AntiVir MailGuard and AntiVir WebGuard therefore cannot be installed. We recommend that you repair the LSP stack and then reinstall AntiVir MailGuard and AntiVir WebGuard via the user-defined installation.
Read moreI tried to crop an image I received an error message when I was running Adobe Photoshop CS6. I can’t resolve this issue even after the reinstalled this program. How can I fix this problem with the proper solution? Any help would be really appreciated.
Adobe Photoshop CS6 Extended
Could not build the Crop preview because of a program error.
Read moreHello experts,
When I try to run Camera Raw on (Win7 x64, the x32 version of CS6 Bridge is installed by CS6 InDesign) using Bridge I receive the following error message. Can anyone provide me the solution to fix this error?
Camera Raw editing is not enabled.
Camera Raw editing requires that a qualifying product has been launched at least once to enable this feature.
Read moreHello,
I am trying to access the 7digital server but it gives me the following server error. Why am I getting this annoying error? How can I resolve this error permanently? I really need your help to fix this issue.
Thanks in advance.
7digitial Server Error
Read moreHello,
I am trying to install NI LabWindows on my Windows XP OS but during the installation it gives me the following error message “installation has failed”. I updated to the latest version but again the same error appeared. Any idea would be greatly appreciated.
Error
The “NI LabWindows/XVI 2012 Network Variable Library” installation has failed with the following error:
An error occurred during the installation of assembly
‘NationalInstruments.NetworkVariable,version=”8.6.20.470”,culture=”neutral”,publicKeyToken=”4544464CDEAAB541”,processorArchitecture=’x86”. Please refer to Help and Support for more information. HRESULT: 0*8002802F.
Continue?
Read moreHello,
I have installed the App-V server on a virtual server running Windows 2008 R2. I am using Windows XP on my laptop and have client installed on it but when I try to load it using virtual application, an error message appears. Any ideal to resolve this error?
The application virtualization Client could not launch report desktop connection manager.
Your Application Virtualization data cannot be accessed. Report the following error code to your System Administrator.
Read more
Hi experts,
I got an error message via serial port with VISA, lab view 2011. It was working fine but suddenly today I received the following error message. I searched the solution from the internet but could not find any solution.
Can you provide me the best solution to resolve this problem?
I would be really grateful.
Error -1073807343 occurred at Property Node (arg 1) in
VISA Configure Serial Port (Instr).vi-> Basic Serial Write
And Read.vi
Possible reason(s):
VISA: (Hex 0xBFFF0011) Insufficient location
information or the device or resource is not present in
the system.
Read moreHi,
When I tried to open Autodesk Navisworks Manage 2012 I encountered the following error message. How can I fix this error? I have tried the solution from the internet but could not find any result. Any help would be greatly appreciated. Thanks in advance.
File Fire Truck_5.skp does not exist or can’t be opened
Failed to create instance of NoW64 loader
Error code: 32769
C:Users17888DesktopNavisworks EntourageVehiclesFire
Truck_5.skp
OK
Read moreHello,
When I install Vuze 4.7 then it hangs my Sony Vaio every time. When I tried to install this program I got the following error message. Help me to resolve this weird error. Any help would be really appreciated. Thanks in advance.
Install4j
An error occurred:
Nanoxml.XMLParseException: XML Parse Exception during parsing of the XML definition at line 1: Expected: <
Error log: C:UsersSleesyAppDataLocalTempinstall4jError2489981020186117000.log
OK
Read more
