Archive
I downloaded Multisim 9 successfully and when I attempted to install this it thrown an error message on the screen. This error displayed at the end of stage and showed “Unhandled Exception”. I reinstall the application but bad luck. What is the cause? How can I fix this? I extremely need your help as soon as possible. Suggest me.
Error Number: 0x80040706
Description: Object reference not set
Setup will now terminate
Read moreHi experts,
Recently, I downloaded ROBOTC successfully on my Windows XP Operating System but when I attempted to install this program an error message displayed showing “Could not initialize application”. How can I remove this Error 42 (IPM)? This is very annoying to me because I can’t continue my work so please guide me with best solution.
Thanks in advance.
Could not initialize application. Error 42 (IPM) Please contact technical support
Read moreHello,
I am getting the following weird Windows system error message. I can’t initialize the application because of the error saying “The application failed to initialize properly”. I have tried to solve this system error but there was nothing to resolve this matter that’s why I need an expert’s advice for the proper resolution.
Thanks for help.
Error: the application failed to initialize properly Click close to exit the program.
Error code: 1142
Read moreHey guys,
All of a sudden my computer has slown down, my browser is slow and when I use programs I get a send error message. I think I need to defragment my disk. I've had my computer for a few years and it's never acted like this. I was told to you eusing register cleaner?
Read moreHey guys,
I am having a few problems with the Rising PC Doctor uninstallation. It is still running in the background after I uninstall it and there are leftover pieces of software all over the place that I can't delete. Can anyone off a solution to my problem?
Any help would be great.
Read moreHey everyone,
What is the limit tmg upload file size? I would like to know the limitations of uploaded file sizes. Can you tell me more about tmg and all the features attached with it? Any help at all with this would be greatly appreciated.
Thank you very much in advance.
Read more
Hey techyv,
I recently installed the trial version of izotope ozone 4 that I had downloaded from there website.
Once it installed however, there is no way to start the program as I can not find it on my computer at all.
There is no shortcut on the desktop and I can not find it at "Start/All Programs/izotope".
Hey guys,
Is there any software available that can track time usage details such as when I turn my computer off and on, how much time I spend on it and how much time I spend on any number of activities? Preferably free but I will pay if it is decent.
Read more
Suddenly, I got the error message using ISA basic 2.0 when I was checking and fixing program for memory leaks then I got the following “Range Check” error. What is the cause? Can I get the solution to resolve it because I did not find any solution during online searching? I extremely need your suggestion.
Thanks in advance.
Error: Range check error.
Read moreHi,
I receive the following error message when I create new feature and click on ‘Edit Components’ and I also get this error during panels. I encounter this message at the two different areas of the website. I couldn’t solve it now I need your help to resolve this issue as soon as possible. Any assistance would be appreciated.
An AJAX HTTP error occurred.
HTTP Result Code: 403
Debugging information follows.
Path:/system/ajax
StatusText: Forbidden
ResponseText:
403 forbidden
You don’t have permission to access/index.php
On this server
Apache/2.2.12 (ubuntu) Server at d7git.I port 80
Read more
