Archive
Hello experts,
Recently, I installed Ubuntu 10.10 and got the following error message when tried to install anything via Software center. I am not able to start anything and receive this error “Failed to lock the package manager”. I have no any other running software then why am I getting this error? Can I get proper solution to fix this issue? I would be greatly appreciated.
Thanks in advance.
Failed to lock the package manager Check if you are currently running another software management tool, e.g synaptic or aptitude, Only one tool is allowed to make changes at...
Read moreHello,
I am running Windows XP Operating System but an error message displayed while running the Task Sequence. An error occurred while starting the task sequence (0x8007000E).I restarted my system and again tried to run this application but the same error appeared. I want to solve this error immediately.
Thanks for any help.
Failed to run Task Sequence An error occurred while starting the task sequence (0x8007000E). for more information, contact your system administrator or helpdesk operator. Click finish to restart the computer
Read more
Today, I got an error message when I was trying to install Zune software and the installation failed. I downloaded this amazing software without having any issue but when I attempted to install this software the installation failed. This is very annoying to me. I have tried to reinstall the software but the error still exists. I want to fix this error so help me.
Thanks for any assistance.
Installation Failed Setup must stop because the required package Zune didn’t install. Error code: 0x80070643 https://support.microsoft.com/en-us/help/11696/windows-phone-7
Read more
Recently, I downloaded 3ds Max 2010 and it was working fine but suddenly I received the following error message saying “The software license check out failed”. I have searched for the solution but there was nothing to solve this issue so I extremely need your assistance to fix this issue as soon as possible.
Thanks in advance.
The software license check out failed. Error 20.
Read moreHello,
I am using Windows XP SP3 and getting an internal error message when writing a file. The Windows installer always encounters this error message and says verify that you have access to that directory. How can I fix this annoying error message? I can’t do anything without your help. Provide any help would be greatly appreciated.
Thanks in advance.
Error 1304. Error writing to file: C:WINDOWSSYSTEM32 THBlmg45.dll. Verify that you have access to that directory.
Read more
Recently, I got an error message when remotely configuring modules or variables for NI 9148 or NI 9146. LabVIEW encountered this weird error message. I searched online for the resolution but I can’t resolve this issue without an expert’s advice. Any help would be appreciated.
Thanks for everything.
Error-1950678962 occurred at open variable connection in untitled 1.vi Possible reason(s): LabVIEW : the specified variable does not support the specified read, write, or open operation.
Read more
I just received this error during the installation of Smart Dialer software and the software has encountered an error. I reinstalled the software as recommended by the EarthLink but the error still existed. Now I am looking for the resolution that is why I preferred to avail an expert’s advice. Please provide any help.
Thanks in advance.
An error has occurred… Error type: smart Dialer Software error The smart Dialer software has encountered an error. Earthlink recommends re-installing the software
Read more
Today, I was installing java application to the directory C:/but during the installation I realized to install it on directory G:/ and cancel it. I reinstalled this application but an error message appeared. How can I remove this internal error? Help me with proper solution. Any help would be appreciated.
Thanks for this.
Internal error 2753. IPAHandler.exe.792D2911_340A_4669_93D8_A38422
Read more
Hello experts,
When I attempted to log into my user an error message displayed saying “The application has failed to start because sfc_os.dll was not found. I tried to reinstall this application to fix this problem but I could not resolve the issue. Now I confused with this error that is why I extremely need your help.
This application has failed to start because sfc_os.dll was not found. Re-installing the application may fix this problem.
Read more
I am using Windows 7 Operating System and getting System Error message that the program can’t start because WMVCore.DLL is missing. I have tried to reinstall the program to fix this program but could not solve this issue. Can I fix this error without having any problem? I really need your assistance.
The program can’t start because WMVCore.DLL is missing from your computer. Try reinstalling the program to fix this problem.
Read more
