Archive
When TurboLaw is checking for updates (either via the automatic check which occurs every time the program is opened) or when you check for updates manually, an "unexpected error" may appear, as shown below. Need your help.
Error: Unexpected Error An unexpected error has occurred. Click "Try to Continue" if you want to try to continue, otherwise click "Exit Program" to close this program.
Read moreHi,
When I install the auto diagnostic tool software, I meet the following error. I have installed the software 2011.3, but I cannot open it. I receive the following fatal error when I try to open the software. Is this problem with installation? How can I resolve the error message? Really want your assistance.
Thanks in advance.
Error: Fatal error OBD2Express.co.uk Failed to laod vehicle selection Application will shut down
Read more
I have installed FTP in my new PC but when I try to run the application I receive an error message. Provide me the proper solution to fix this problem. Why did this error appear? I really want your suggestion.
Error: Error Loading Configuration Files….
Read moreHello experts,
Cannot clone VM using VBox 4.1.0 because 'VBoxGuestAdditions.iso already exists' I have a problem when using VBox 4.1.0 to clone a VM. I chose to clone the current state of one of my VM's and left the check box 'Reinitialize the MAC address of all network cards' clear. Help me to fix the following error.
I would be grateful to you.
Error: Failed to clone the virtual machine RSD_Centos5_5_x86_64_A. Cannot register the image ‘C:Program FilesOracleVirtualBoxVBoxGuestAdditions.iso’ With UUID {0bda623d-b3cd-4e9a-b639-6acd8a611456}because a CD/DVD image ‘C: Program FilesOracaleVirtualBox/VBoxGuestAdditions.iso’ With UUID {0bda623d-b3cd-4e9a-b639-6acd8a611456} already exists. Details Result Code: VBOX_E_INVALID_OBJECT_STATE (0x80BB0007) Component: VirtualBox...
Read moreHello,
I got an error message on a 6680 using DEJAN Software and can’t read SP data. You can see the attached error image with full info. What is the main reason of this problem? Can I resolve this issue? Any assistance would be really appreciated.
Thanks in advance.
Error: BB5 Unlocker by logs v1.0b by Dejan Kaljevic © 2006 Phone ID: V3.0436v32 04-01-05 RM-1 ©NOKIA. IMEI: 355677001460076 SP Ver: SIMLOCK SERVER VERSION 53 SP_F: 0000000000000000 SP_P: 23430000000000000 SP LOCK Status: LOCKED! TRY1:=3 TRY2:= 0 Wait…! Error: read pm data !
Read moreHi,
I am using Windows XP SP3 and have uninstalled V3 to install V4 (Firewall only) but I could not install successfully and error displayed during the installation. Can I fix the following error message? What is the cause of this problem? Any idea would be appreciated.
Error: Cannot install C:ProgramDataComodo DownloaderCIS_Setup.msi Error: 1603. Fatal error during installation.
4.0b Beta 2: unknown software exception 0xc0000005 in iexplore.exe attempting to go to Google Maps from Biblical Places Open Biblical Places (it happened to open to "Tarshish (port city)". What is the cause of this error message? Help me to fix this.
Error: iexplore.exe – Application Error The exception unknown software exception (0xc0000005) occurred in the application at location 0x7698ba0b. Click on OK to terminate the program
Read moreHello,
When kicking off the installer (double-click the installer from Explorer) for the latest WSX release (1.0.1) on Windows 8 (RTM), I am getting the following error. I am expecting your suggestion from you. Any help would be really appreciated.
Thanks in advance.
Error: Windows - Application Error The exception unknown software exception (0xc0000417) occurred in the application at location 0x6c49c497. Click on OK to terminate the program
Read moreHi,
I have ConvertXToDVD software and it was working fine without having any problem.Now I have problem using this software and showing the access violation error. How can I overcome this problem? What is wrong with this software? The reinstallation did not fix the issue. Help me to resolve the error.
Error: Access violation at address 09B21146. Write of address 00000034.
Read more
While using Adobe Audition CS6 an error occurred that “ThinApp Crash in RelaunchUsinCreateProcess”. I haven’t encountered this error before using this application. What keeps this from occurring?
Any ideas or solution you may suggest for this matter?
