Archive
The program is not installing on the computer and displays the internal error 2753 which is associated with Windows Installer. Can I fix this issue? Provide the resolution step by step. It would be nice to share any idea about this error.
Thanks in advance.
Error: Internal Error 2753. IPAHandler.exe.792D2911_340A_4669_93D8_A381422169D60
Read more
I have been using IMVU for at least 3 years as far I know. It baffles me that for the first time I logged in an error message keeps showing up saying that “Oops! IMVU has encountered a problem.
Your software will send us a message describing the problem so we can fix it!”. This message keeps appearing for the past few weeks every time I try to access it. What is the fix for this?
Thanks in advance.
Oops! IMVU has encountered a problem. Your software will send us a message describing the problem so...
Read moreHello,
I have a Maxtor One Touch 4 external hard drive. Model No. 9NT2A4-500. My problem arises when I try to update the current software of Maxtor Manager. First I get the following message: Available version: 4.01.0303 Installed version: 4.01.0227 Do you want to install? -> 'Yes' Shown images error:
Suggestion would be helpful. Thanks.
Error: Error while connecting support site: https://www.seagate.com/nl/nl/search/?keyword=Seagate%20Manager%20Software
Read more
Hi experts,
The following error shows Native Extension Tip // ld: framework not found. This error comes up using ANE’s. Is there any way to resolve this issue? I am waiting for your help so that I may fix this problem as soon as possible.
Bundle of thanks.
Error: ‘Launcing … has encountered a problem. Error occurred while packaging the application: Id: framework not found … Compilation failed while executing : Id64
Read moreHello,
I am trying to install Microsoft .NET 3.5 framework which is the requirement of eC-AuditTool. I encountered the following error message during the installation of .NET framework. How can I fix this Setup error? I tried to search the solution from the internet but I think I need your assistance. Any help would be appreciated.
Error: Component .Net Framework 3.5 has failed to install with the following error message: "Fatal error during installation." The following components failed to install: - .NET Framework 3.5 See the setup log file located at ‘C:DOCUME~1DONSCO~1.DONLOCALS~1TempVSDAD.tmpinstall.log’ for more information.
Read moreHi,
Shouldn’t require mscvr110.dll, How can I fix Borderlands.exe application error? I am using Windows 8 OS and installed this game but when I tried to start this game it gave me the following error “The application was unable to start correctly”. Help to fix this.
Error: The application was unable to start correctly (0xc0000142). Click OK to close the application.
Read more
I am trying to start Apple iTunes but the program can’t start because the following error shows “AVFoundationCF.dll is missing”. Can I fix this problem without having any problem? I really need your assistance to remove this system error.
I would be grateful to you.
Error: The program can't start because AVFoundationCF.dll is missing from your computer. Try reinstalling the program to fix this problem.
Read moreHi experts,
I am running Windows 7 Ultimate x86 and I got the following error message when X-Blades was loading after complete level 1. I have installed the new driver but the fatal error remained. How to fix this problem? Any suggestion would be really appreciated.
Error: Progengine2memorydagmem.cpp,650: Not enough memory in realloc(00000000,-1179869200) call Call stack (0 frames):
Read more
Currently I am in to IMVU. I have read this tutorial on how to create a voice box some Visual Basic scripting. While doing so an error message pops out saying that “Something has caused an error during saving”, more details are provided below. What did I do wrong for this to come up? Any solution for this?
Something has caused an error during saving. We don’t have full coverage in this area but will review this error to resolve the issue.
Read moreHi,
I am getting the error message which says “D3DRM.dll not loaded”. This file is for direct3D which is an old DirectX display technology and also part of the Windows OS. This file plays an important role in rendering 3D images in the critical situation. How can I resolve this error message? Please provide the solution for the resolution of this error.
Error: D3DRM.dll not loaded.
Read more
