Archive
Hello experts,
I have installed mono-android-4.4.41.176656956 after installing this I have got an error message “error attempting to initialize the MonoAndroidPackage”. Is this a problem with Microsoft Visual Studio? How can I overcome this annoying error? I need assistance to resolve the matter.
Error :
There was an error attempting to initialize the MonoAndroidPackage: System.ArgumentNullException: Value cannot be null. Parameter name: path1 At System.IO.Path.Combine(String path1, String path2) At Xamarin.AndroidTools.AndroidSdk.get_AdbExe() At Mono.Android.VisualStudio.MonoAndroidDeviceManager..ctor() At Mono.Android.VisualStudio.MonoAndroidSdk.get_DeviceManager() At Mono.Android.VisualStudio.MonoAndroidPackage.Initialize()
Read moreHi,
I got an errorr 32110 on Windows 2012 machine when installing vCentre 5.1.0 while selecting the supplied SQL Server Express edition for database. How can I resolve this error message? Is there any cause of this error? Any help would be appreciated.
Error:
error 32010. Failed to create database users. There can be several reasons for this failure. For more information, see the vmMSSQLCmd.log file in the system temporary folder.
Read moreHi,
Rainmeter version is not supported error to install the skin higher version skin. Rainmeter is the best system-monitoring application let you to apply custom gadgets like skins in your desktop screen.
Rainmeter skin is easy to create but some downloaded skin required latest version, it gives windows version error.
Help me.
Thanks in advance.
Error:
Rainmeter 2.5.0.1792 or higher is required to install this package.
Get the latest version from rainmeter.net and try again.
Read moreHello,
Missing Internet Explorer and .NET Message PLEASE HELP!! I have both .NET and Internet Explorer 9 yet that message comes up all the time when I try to attempt to download this game. This is probably the game that gives me a hard time because it just doesn't know I already have these programs installed. Please Help!!
Am also getting error as .Net 3.5 SP1 and Internet explorer is missing. I already have the latest 4.5.Net and Latest explorer 9.
Error: The application failed to initialize properly. Common causes are missing .NET framework 3.5 SP1 or Internet...
Read moreHello,
I am trying to download the latest Intel perceptual computing SDK but it fails giving me the following output (snapshot attached) Installation Aborted: Failed to download the configuration files My system information: Windows 7 64bit, Intel Xeon CPU E5440 @ 2.83 GHz with 4 GB RAM. What may be causing this error? Have any idea about this issue?
Error:
Intel® Perceptual Computing SDK 2013 Installation aborted; Failed to download Configuration files.
Read moreHello,
I am using Windows 7 Ultimate and have noticed that steam will no longer open after steams latest update of july31st, 2012. How can I fix this issue to resolve the following issue? Any suggestion would be really helpful to me.
Thanks in advance.
Error:
Steam.exe(main exception): ERROR: copying SteamNew.exe to Steam.exe failed, Win32 Error 32 "The process cannot access the file because it is being used by another process."
Read moreHello,
Whenever I try to login back I got the following error message in crypt of kings and game got crash. I receive this annoying error message until game reset my position. How can I fix this issue permanently? I really need your help to resolve the error.
Thanks for everything.
Error:
***ERROR*** Application: ??? Thread: GraphicsInterface Thread Error: StreamModelLodeaer: ‘httpnz://drasaonline.l3.cdn.bigpoint.net/cdndate/export_win32/models/t002_crypta_05_cultists/s05_tile_ground_pattern_quad_01.n3’ is not a N3 binary file!
Read moreHi experts,
I'm experiencing similar troubles with X-LibreOffice 3.5.0 rev8 on XP. I suspect that it's the same issue you have with X-Gimp. When I double-click the launcher I get this message. Can I receive the proper solution to resolve this error message? I would be grateful to you.
Thanks in advance.
Error:
Impossibile avviare I'applicazione. an error occurred during file opening
Read moreHello,
It happens on all Czech Windows XP versions. But it's interesting I can't Zen open in Reaper either - it says me an error during scanning. I'm sad This is the REAPER error window. Can I get the resolution for this issue?
Error:
Plug-in ‘Zen.dll’ executed invalid operation during scanning Note: if REAPER crashes as a result of this, simply run it again and it will continue on the next plug-in.
Read moreHello,
When I tried to use Vls from the Report Generation Toolkit for Microsoft Office I got the following error message. I have installed Report Generation Toolkit for Microsoft Office with LabVIEWand whenever I try to place VIs from that toolkit on my block diagram I get Error -2147221164. Why is this happening and how can I fix it?
Error : Error -2147221164 occurred at Class not registered in NI_ReportGenerationTollkit.lvlib:ex_RGT_Get Bookmarks and Named Cells.vi->NI_ReportGenerationToolkit.lvlib:Configure MS Office Report.vi->NI_ReportGenerationToolkit.lvlib:Configure MS Office Report.vi.ProxyCaller This error code is undefined. No one has provided a description for this code, or you might have...
Read more
