Archive
I have got the following error message while installing the Nokia Suite using Windows 7 Operating System. The error shows “An error occurred during the installation of assembly”. Please help me with full information. Any help would be greatly appreciated.
Thanks in advance.
Something’s gone wrong
An error occurred during the installation of assembly ‘Microsoft.VC90.MFC, Version=”9.0.30729.4148”, publicKeyToken=”1fc8b9a1e18e3b”, processorArchitacture=”x86”, type=”win32”. Please refer to Help and Support for more information.
Read moreHello,
Recently, I was trying to update my Skype on Windows 7 Operating System.
During the installation of Skype I got the following error message saying “The installer has insufficient privileges to access this directory”.
I have reinstalled this program, but the same problem exists.
I need your suggestion with full instructions.
I would be grateful to you.
The installer has insufficient privileges to access this directory:
C:ProgramDataMicrosoftWindowsStart MenuProgramsSkype. The installation cannot continue. Log on as administrator or contact your system administrator.
Read moreHi,
I am running Windows XP Operating System and attempted to send a Corel X5 file using Skype but I got the following weird message and needs to close. How can I prevent the error message? What is the cause of this error? Suggest me properly.
Thanks in advance.
bavani anatha: Skype.exe- Application Error
The exception Floating-point division by zero.
(0xc000008e) occurred in the application at location 0x66e9433c.
Floating point division by zero.
Read moreHi,
Recently, I purchased Nero 12 Software but I got the following error message when I attempted to start this software.
The error is saying some configuration problem as you can see below.
Can I get the proper instructions to start this software?
I want to use it properly so provide the solution to remove the error.
Thanks in advance.
C:Program Files (x86)NeroNero12Nero VisionNeroVision.exe
The application has failed to start because its side-by-side configuration is incorrect.
Please see the application event log or use the command-line sxstrace.exe tool for more detail.
Read moreHi,
Recently, I was store my photos using Windows Live Photo Gallery on Windows 7 OS but when I attempted to save my file I got the following error message. All other programs are working fine. Is this the problem with file or anything else? What could be wrong with this file? I need your help to resolve the issue. Provide solution.
This photo can’t be saved because of a problem with the photo’s file properties.
Read moreHello,
Recently, I installed the Windows 7 Operating System and tried to update my Window. During the installation process of updates the following error message appeared saying “Some updated were not installed”. The error displayed during the installation of IE 10 for Windows 7. Can I get the resolution to fix it?
Thanks for any help.
Some updates were not installed
Failed: 1 update
Error(s) found:
Code 9C59 Windows Update encountered an unknown error.
Get help with this error
Most recent check for updates Today at 6:03 AM
Updates were installed Today at 6:33 AM
View update history
You received update For Windows and...
Read moreHi,
I have installed Windows 8 Operating System but I can’t open web pages on Internet Explorer 10. The following error message appears when I try to open IE 10. The internet connection is working and mail is also fine but how can I fix this issue? I really need your help. Any help would be appreciated.
WerFault.exe - Application Error
The instruction at 0x77911bb8 referenced memory at 0x77911bb8. The memory could not be written.
Click on OK to terminate the program.
Read moreHi,
Recently, I have installed and uninstalled a myriad of programs during the course of trying to diagnose the memory problem. Now I am not able to play Windows media Player if I go to the Music or Video sections the Media Centre crashes. I got the following Server execution error message whenever I try to play an audio file. How can I fix this error? Have any idea?
Thanks for any assistance.
C:UsersBradfordDocumentsbluedragon.wmv
Server execution failed.
Note: Similar post exists on techyv.com but with no IMAGE file.
Read moreHello,
I am trying to use Office Pro Plus 2013 that includes Lync 2013 but now I am not able to connect Lync with Office 365. I have also tried to use the online assistance but nothing happened. How can I connect it properly? Is there any problem with the server? Need assistance.
Thanks in advance.
Can’t sign in to Lync
The server is temporarily unavailable. If the problem continues, please contact your support team.
Still not working?
Read moreHi experts,
I was able to use the TechNet Terminal Services and now I decided to use the Office 2013 but I am not getting the keys for Remote Desktop. When I used the existing keys and try to run setup.exe from the Office 2013 that I have downloaded from the TechNet I received the following error message. Now I really need your assistance to resolve this issue.
This copy of Microsoft Office 2013 cannot be used on a computer running Terminal Services. To use Office 2013 on computer...
Read more
