Archive
I am running Windows 7 Operating System and trying to download Microsoft® DirectX®. I have downloaded it successfully but when I clicked to install the setup an error occurred at the end of the stage saying “An internal system error occurred”. I really need this software to play the games so please guide me the proper instructions to install it without having any problem. I have reinstalled this application but I need expert’s advice. Help me!
An internal system error occurred.
Please refer to DXError.log and DirectX.log in your Windows folder to determine problem.
Read more
Today, I have downloaded Kaspersky Internet Security 2012 and during the installation process an activation key was required to continue the installation. I searched the code online for activation but it did not work for this application and an error appeared saying “Activation code is suitable for this application”. Can I get the proper code to activate this application?
I would be greatly appreciate any assistance.
Activation error
Activation code is suitable for this application.
Read more
I am trying to install Autodesk Inventor 2012 but it gives me the following pop up message during the installation process. Some unknown file is missing according to the given error. I reinstalled the program but the problem remains. Can I fix it? Help me to get it out.
Thanks for any assistance.
adlmPITValidateKey was not found in
//windeploy.ce.gatech.edu/programs/AutoDesk/2012/Inventor_64/Setup/adlmPIT.dll!
Read more
Recently, I have downloaded Acronis True Image Home 2012 but I got the following error message during the installation of this software saying “An error occurred while installing Acronis True Image Home 2012”. Can I get the proper instruction to install it without having any problem? An help would be appreciated.
Issue description:
Installation has failed.
The value cannot be found.
Read more
I am getting the following error message while the lessons are being closed. Is this the problem with articulate player?
How can I fix it?
What is the main cause of this error?
I need your suggestion to resolve the matter.
Thanks for any help.
LMS Message (Thu Feb 02 2012 17:21:35 GMT-0600 (Central Standard Time)):
Failed to save your progress. Http Status Code of 0 was returned.
Press OK to save your progress again cr press Cancel to close this course.
Read more
I have upgraded vCenter from 4.0 to 4.1 and have 2 templates in my vCenter installation. I can convert it to Virtual machine and back to template. Now I am getting the following error message after converting to VM. I cannot edit machine anymore nor migrate the template anywhere. Have any idea? Help me to resolve this issue.
The server fault ‘System Error’ had no message.
Call "PropertyCollector.RetrieveContents" for object "propertyCollector" on vCenter Server "vCenter.mydomain" failed.
Read more
Hi experts,
Recently, I got the following error message when I tried to start Eclipse. What is wrong? How can I resolve this error? Provide the step by step solution. I would be grateful to you. I have tried online solution but I need your assistance.
An error has occurred.
See the log file
/eclipse/configuration/1330662900169.log.
Read more
I am trying to open the Bandicam for the audio recording but I am unable to use this properly. When I start this for the recording an error message appears like a weird deal. Is this the configuration problem? Can you send the proper instructions to use this software on my Windows 7 Operating System?
Thanks in advance.
Read more
Recently, I have updated the latest version of Thunderbird. When I launch the Thunderbird after updating, two message windows are always being displayed. When I close one message both are close. What is the reason for this error? How can I remove the following error message? I really need your help to resolve the issue.
Thanks in advance for any help.
Alert
This folder is being processed. Please wait until processing is complete to get messages.
Read more
I have downloaded the latest version of Nokia Suite from its official website but when I attempted to install the file I received the following error message “problem with the installation file”. I searched online for the solution but I couldn’t find the solution. Now I need your assistance.
problem with the installation file.
There seems to be a problem with this installation file. To be able to install Nokia suite, download the latest version from..., Error code 0x80096010
Read more
