Archive
I am using Microsoft Office 2010 32bit bit I am having the following error message when I double click the icon to open my application. I tried myself to resolve the following issue but it would be better to consult with expert’s advice. Any help would be great.
Thanks for everything.
Error:
Compile error in hidden module: mMacros.
This error commonly occurs when code is incompatible with the version, platform, or architecture of this application. Click “Help” for information on how to correct this error.
Read more
I am using ConvertHLink contained within the same module having two macros or sub procedures. Why am I having this error “Ambiguous name detected: ConvertHLink? Can I get the solution to fix this problem immediately? Any assistance would work for me.
Thanks in advance.
Error:
Compile error: Ambiguous name detected: ConvertHLink.
Read more
I have got the following error message after importing a newly sequenced application into the Management Server. I couldn’t find any resolution to resolve this annoying error. I have heard about you that my problem can be solved here so I request you to resolve this issue. Any help would be really appreciated.
Thanks in advance.
Error:
The version lineage specified for package(C92952B7-A07A-4792-9D88-92672F44DFEF) is invalid.
Error code: 0000BD39
Read more
Hello Techyv Guys,
I have been searcing for a tool that will convert xml coding to corresponding sql coding. Is it possible to have a tool or to get xml to sql converter open source coding. Please help me by providing the same asap.
Thanks you in Advance,
Lance Sok
Read more
I have installed Microsoft Office 64bit version including StatPro and all other add-ins for Office but the StatPro is only compatible with the 32-bit version of Office. How can I demolish the following error message using 64-bit version of Office. I really need your assistance so provide the best suggestion.
I would be grateful to you.
Error:
Compile error in hidden module: mdlShellOps.
Read more
Hello:
I am getting the following error message using StatPro and I can’t save.xla files in a different folder except where the StatPro is saved. How can I remove this error? Have you any idea to remove this issue which occurs in Excel. Suggest me the way to fix it.
Thanks in advance.
Error:
Error number:1004
Description: ‘C:UserscbesterDocumentsBusiness Statistics 41000Fall2011StatProTSPlot.xla’ could not be found. Check the spelling of the file name, and verify that the file location is correct.
If you are trying to open the file from your list of most recently used files, make sure that the file has not...
Read more
Hi All,
I am using Windows XP, and I am in need of a dat to bin converter freeware that will work in my Windows XP.
Please do the needful for suggesting the converter name along with a download link towards it.
Waiting to hear from you.
Thanks from Kurt Tedo
Read more
When I attempted to use the articulate features in PowerPoint I encountered the following Microsoft Visual Basic for applications error. Is this the compatibility issue or anything else? Can I resolve the error without any trouble? Provide assistance with details.
Error:
Compile error in hidden module: bConstantsAndAPIDeclarations.
version, platform, or architecture of this application. Click "Help" for
Read more
Hello Friends,
I am using Linux, I would like to have jpg to pnm linux conversion software, that will convert files in batches as well as in single. Please suggest me a better freeware jpg to pnm conversion tool that will work in Linux.
Thanks for the Support, Alland Ornad
Read more
Hello Techyv Guys,
I need a small support from Techyv Experts, Please do the needful for letting me know about Sencha Touch timetable i.e., adding of an Event Listener. Please do the needful for explaining me along with a sample coding for a better understanding.
Thanks and Regards,
Neil Rabon
Read more
