Archive
Hi techyv,
I am looking for the best editor for mac osx.
 I’m using NetBeans which is fine and also supports auto complete for a lot of classes/methods used by CI.
But I want to know the best coding tools to work with codeigniter.
What's the best possible editor?
Thanks all.
Read more
Hi guys,
Hello, I installed er mapper plugin autocad 2002 to open images on Autocad 2002.
When I do a general zoom in it's regenerated with sufficient resolution for reading.
But when I go in the presentation window with a zoom tightens the definition doesn't change.
How do I fix this?
Read more
Hey guys,
The problem is that when I put the file in the remote server drops the connection and a blank file appears at the end.
There are no authentication issues.
I'm testing against another SFTP server running OpenSSH and it works just fine.
Would could the problem be?
Read more
Hi everyone,
I want to use Excel 2010 to Oracle ODBC to query data, but I don't want to install the Oracle Client through ODBC.
Is there an easy solution to this problem?
Can some one tell me how to do this?
Any help at all would be excellent,
Thank you.
Read more
Hi guys,
I recently noticed that some of the backlinks within Google Webmaster Tools is missing.
I’ve quickly checked the site and lots of Them are gone.
Are there tools for missing links in websites that I can use to retrieve the backlinks?
Or is there no solution for this problem?
Read more
I've been trying to install and then register my Avast! Free Version but it always failed. What are the steps on doing it correctly? Please cite the step-by-step method. Thank you.
Read more
Hi techyv,
I know each one would have overall positive and negative qualities but the mainly purpose is the Microsoft office package  in particular Microsoft outlook 2010 portable.
What is the best Smartphone to use for my purpose?
I was leaning towards some type of blackberry but I am more than open to suggestions.
Read more
Hi everyone,
Me hard drive has recently malfunctioned and a lot of different folders in my drive are now gone.
I was wondering if I could use techtool pro 6 to not only recover my deleted files but also fix the issue I am having with my drive?
If yes how would I do so?
Read more
Hi everyone,
I recently received the Bento 4 mac but I am having a slight problem with I print documents.
When I first printed a document the font size was to small so I adjusted it.
But when I printed another page the writing had not changed.
How do I effectively change it to a standard size?
Read more
Hey guys,
Can c++ or operator be done? The code is:
if((a ||b)==0)return1;
return0;
boolCircle2::contains(Line2l){
if((p1.distanceFrom(l.p1)||p1.distanceFrom(l.p2))<=r){
 return1;
 return0;
Is the coding in the second piece the problem? Any help would be awesome.
Read more
