Archive
During my free time I do graphic design and I like playing around with pictures. I have DirectDraw installed on Windows 7 and it has been showing an error message as displayed below. I have verified that my computer meets minimum requirements so what can I do next. I would like to solve this soon.
Could not initialize graphics system. Make sure that your video card and driver are compatible with DirectDraw.
Read more
Greetings,
I have a question concerning the editing of PDF files. I have a class project that I wanted to edit some few things but it is in form of PDF. So I installed Adobe Acrobat, problem is whenever I try to open the document I get an error as shown below. Can anyone help?
Adobe Acrobat
There was an error opening this document. The file is damaged and could not be repaired.
Read more
I had installed the Nitris Video LHAL on Windows 7 and after using for some time I got the error shown below. This error shows up when I launch the program. Where can I get the drivers of Nitris LHAL so that I can update them?
Nitris LHAL
Nitris Video LHAL :: Nitris driver have incompatible firmware revision, please update
Read more
As an engineer I have been using the ARIS Express software to create very complicated designs. I have used it for a while now but suddenly I can’t save my models as it popping up an error as shown below. I have tried opening other designs and they open but only problem is saving new designs and saving changes to already saved designs.
Error
Save operation is not possible. Internal Error: Internal error: Unable to save the model.
Read more
I am a student and I use Microsoft Word 2007 every now and then. There are some functionalities that I do not understand well such as creating table of content and also mail merge. When I try to access Word hlp I ran into the error below. I am stranded now on what to do.
CLView
CLView can’t display help.
CLView cannot install the necessary files due to Windows installer error 1706.
The endpoint format is invalid
Read more
Hi guys,
Corel Designer has been disturbing my peace since it started showing errors. I installed it to be able to do my designs on computer instead of on paper. Whatever file I choose to open is displaying an error. I have already used it to create some projects so I have like 3 projects that cannot open and they are giving me a headache. Is there something am missing out?
Corel Designer
Either ‘D:userdataqa1952DesktopmikePresentation1.ppx’ is not importable using the selected filter, or this format is not supported.
Read more
Hello everyone,
I have an issue with the ARIS Express modeling software. I was able to create my designs after installation but the next day it showed up an application error preventing it from launching. Has anyone seen this before or is it just unique to me?
Application Error
Unable to launch application.
Name: ARIS Express 2.3
Publisher: Software AG
Read more
I thought of using the SugarSync software to be able to sync my photos and music on my PC running Windows Vista. The problem is that I have an annoying error that leaves me bored it says the Magic Briefcase folder cannot be located. Has anyone experienced such before?
Scan to SugarSync
Failed to locate the Magic Briefcase folder. Specify your SugarSync folder as the destination in the “Scan to SugarSync” dialog box.
Read more
I created a .AIRA file but every time I try to play it I get an error message as shown below. I am not a professional on this matter so I will appreciate very much if you keep your suggests as simple as possible.
Unable to create filter graph.
Unable to create filter graph. Please reinstall AiraPlayer
COM error: STG_E_INVALIDHEADER (0x800300fb) in file .FrameBuffer.cpp:97
Read more
I had installed Avid Media Composer on Windows 8 to be able to create short films of my graduation videos. The installation went through but then I could not run the software because of the error represented below. Is there anything I can do before contacting Avid because I would like to solve it soon and I can’t wait for Avid to receive my problem.
Your system is not licensed to run this software. Please contact an Avid representative for further assistance.
Read more
