Archive
I want to install on-board GPS on my Blackberry 8310. I am located in Australia and found only two applications for Australia. Would you know of other software options for on-board GPS specifically for Australia? Can you tell me what features differentiate the different trackers and software for on-board GPS? And lastly, is a 2GB Micro SD card adequate to accommodate an on-board GPS application?
I would really appreciate your help.
Read moreI upgraded my PC to Microsoft Vista operating system. After completing the upgrade, I proceeded to set up Corel Draw. The Corel Draw setup failed to complete and I got the following error message: failed to install IS Kernel Files, make sure you have appropriate privileges on this machine. Should I uninstall Corel Draw then install it again?
What is the best way to proceed?
Read moreHello,
I was doing some computation with Microsoft excel 2007 and I am having problems with working on formulas. It shows a circular reference warning. What does it mean in layman's term and how do I correct a circular reference warning? Here is a screenshot of my problem. Can anyone help me with this? Thank you very much.
carlo
Microsoft Office Excel
Circular Reference Warning
One or more formulas contain a circular reference and and may not calculate correctly. Circular references...
I have a Windows 2003 Network Operating System organized to be my domain controller. I acquired a new computer with the intention of utilizing it as my new server. I would like to move all my accounts and configurations to my new computer/server without having to build it up from the beginning.
Can you advise me on how to proceed?
Thank you.
Read moreI have a Blackberry which I am syncing with my Outlook. I have no problems in getting them synced. However, meetings that I enter in the Blackberry do not appear on Outlook. But if I add a word or letter in the appointment that I entered in the Blackberry, then save that appointment, it appears in my Outlook.
I am using Blackberry Desktop Manager (BDM) to sync. How can I make sure that all my meetings, whether entered in the Blackberry or in Outlook are always synced and appearing on my Outlook Calendar?
Thanks for your help.
Read moreI have a USB flash drive on my computer. Is it possible to install Linux or Ubuntu in my USB flash drive and start up my computer from there? Will I still be able to get into all files, change printing options and do other things if I log in to my computer using the USB flash drive? What effect, if any, would it have on my hard disk? Thanks for your help.
Read moreI love using the Google Toolbar because it has a lot of uses for me such as bookmarking a website; checking a website’s page rank; translating text and many other things. However, I am not able to take advantage of it when I use Google Chrome. Can anyone explain to me why I am unable to use the Google Toolbar in Google Chrome?
Read moreI am using Windows Vista Home Premium on my computer and have an external drive attached. I need to transfer a 4GB file to another computer. I attempted to do this by copying the file from my computer’s hard drive to the external drive then move it to the other computer.
The external drive has 320GB capacity which is more than enough to accommodate the 4GB file. However, I keep getting a message that the 4GB file is too large and cannot be copied to the external drive. I attempted to copy it to a flash drive with a 16GB...
Read moreI am using Ubuntu 10.04 as my server giving me root access to modify or install whatever needs to be modified / installed. I have reasonable experience in Linux but I have never had to modify email servers so I have very limited experience in what I am trying to do. Basically, I would like to forward all emails sent to me to another email address where I will send emails or replies when needed.
I do not want to send emails or replies from my own email. How can I do this? Thanks.
Read moreI am curious why the settings I chose in my PC for surfing the internet do not get saved. Every time I use the internet, I cannot see the pages of the websites I go to. I always have to check the settings and change the proxy settings and uncheck the box for “Use a proxy server for your LAN.” I have to do this every time, but after I’ve changed the settings the web pages come out without any more problems.
Can you help me how to keep the proxy settings I’ve chosen? Thanks.
Read more
