Archive
My computer system is encountering an error repeatedly while running PCHealth GPF Test Utility.
Earlier this program used to work fine. But now as soon as I even try to start this program, it displays an error message and asks me to report this problem to Microsoft.
Could you please guide me as to what the problem is and how it can be resolved?
Thank you in advance.
PC Health GPF Test Utility has been encountered a problem and needs to close. We are sorry for the inconvenience
If you were in the middle of something, the information you were...
Read moreHi, techyv.com experts I need a favor that I need to know How do I change my IP address?
I use a computer with windows XP & with broadband Internet connection & I got an IP address automatically from my Internet service providers now I need to do change it.
I need to do it manually with
IP address
Subnet mask
Default gateway
Preferred DNS
Alternate DNS
I changed this type of above objects
IP address 148.42.145.185
Subnet mask 255.0.0.0
Default gateway 148.42.145.1
Preferred DNS 116.193.170.5
Alternate DNS 116.193.170.6
After that I did not have any Internet connection & then I had to turn on automatic IP address connection. Really can I get...
Read moreHow can I fix this error message, “The URL was in general failure and xxxxxxxxxxxxxxx error occurred in sending the command to the application”? This happens whenever I click on a hyperlink provided in an email. I have my Windows 7 OS and 64 bit version of Outlook 2010.
Where could I also find some latest fixes for Outlook?
Read moreRecently, I encountered this error on my Skype login window. It says that I need to restart Skype.
I have restarted Skype many times but the problem persists.
I even restarted my windows several times.
I never got this error before.
Please help me convert MS Office documents to PDF with C# program. I also need help to convert Word files to be like Excel files and PowerPoint files and etc. with some reference to microsoft.office.interop.Word and microsoft.office.interop.powerpoint. I am a C# developer. I need really your help on how to convert these files.
Read moreI can’t make any changes within the advanced search filter on my left screen and I can’t add/edit any of my templates because the Add/Edit button disappears below the bottom of the screen. And I can’t also scroll down that far. This happens after I installed Vuze 4.7 to my newly re installed Window XP. Do you have any advice about this?
Read moreMy ZTE Wireless Broadband USB modem has been working well until a few days ago when I gave away my laptop to a friend for a few days. When she returned it, the modem could not connect to the internet, and shows the error in the picture attached. What might be the problem?
Opening Port....
Error 797: A connection to the remote access server was not made because the modem was not found.
If you continue to receive error messages, you can enable logging for analysis.
Enable logging for logging option.see diagnostics
Logging option can also be accessed by clicking the...
Read moreAfter I try to mount one of my 1TB external USB hard drive with True Crypt encryption, there’s an error message which reads, “hdiutil attach failed no mountable file systems”. Then I cannot log-in even if my password is correct because there’s an error message which says “not a True Crypt or Incorrect password”. I always make a format to my eternal drives as bootable for Mac OS X Extended Journal. The True Crypt Volume is also bootable for Mac OS X. These drives have been working and turned on after I attached it to my Mac OS X....
Read moreI need to configure Quick SSL Premium SSL certificate in Parallels Plesk 9.5.4. This runs on my VPS server. Everything worked smoothly but when trying to run a secure page, I got an error “This Connection is Untrusted.” What is the cause and fix for this? Help me. Thank you.
You have asked Firefox to connect securely to strathcairn.com, but we can’t confirm that your connection is secure.
Normally, when you try to connect securely, sites will present trusted identification to prove that you are going to the right place. However, this...
Read moreI am encountering issues after forcing for an update on my Cisco Clean Access Agent program. When trying to use it, it has “Network Error! Detail: Unknown String” error and I can’t use the software. This runs on my Windows Vista 32-bit PC. I updated it to 4.1.2.4 and after that, it just started to run falsely. I tried to uninstall, re-install and run system restore but I was unlucky. How can I fix this?
