Archive
“No package found” – this log appeared on the server when I downloaded a package.
The client page shows: Package Test (1318435297) (Server: local host/download) Status: NOTIFIED (Wed Oct 12 15:52:42 2011)
What would be the problem in this issue?
Read more
I am on Exchange Server 2007 with 1 and 1 when I utilized Proxy settings on Mac Outlook 2011, it worked successfully. The problem was I cannot surf the internet.
What do I need to perform?
Read moreNcFTPd is listening to all IP address for the PC. It will be good if it can configure the NcFTPd to listen pre defined addresses. How can the NcFTPd can utilize more than one network interface in multi-homed PCs?
Read morePlease help me to fix the error ‘un defined reference to f – xargc’. Also the underscore problem is to be solved.
How can I tell the linker to ignore the unresolved reference?
The MKL with PGI compiler can be used and if can be used how can it be used?
Read moreHi Guys,
I need some help
https://www.phplivesupport.com/?
At this site you can see "PHP Live" Plugin. I need such type of plugin free of Cost. If any one know please tell me. Only that person give answer who use it because other person don't know what i am asking.
Read moreWhat can be the pronunciation of HerrWirth’s name? How can the Modula 2 fit to language zoo? What is the difference between Modula 2 and Pascal. Any idea about ISO standard Modula 2?
Read moreThe application Preview is freezing on my iMac running Mac OS X Lion. I have two documents open, and when I try to open another document, the Preview menu bar turns dark, the documents that I already have open appear darker, and there is a spinning, gray wheel in the middle of my screen.
The third document does not open and I cannot choose any of the menu items. When I press Command-Q to quit, nothing happens; the spinning wheel continues to spin. I can switch to another application, and when I come back to Preview, it looks the same....
Read moreWhat is the differences of C - from UNCOL?
Why there is no change in Syntax under C - from
C -.l am not able to locate the source code.
Where is the other C - ?
Read moreWhat are the machines supported by the compiler.
What are the difference of C from CLR and JVM?
Why is there is no garbage collector included in the system?
Read moreI am using Visual Studio C Builder and other compilers except mingW/gcc. I need to know how the Math GL library is linked. Also I need to know about building Math GL in Windows. It is to be created GLUT/FLTK/QT windows with calculation in parallel.
Read more
