Archive
The procedure of authentication does not get to the end every time I try to log in. It tells me to specify the correct username and or password.
Does anyone have any information as to why am I getting this message?
Error
Specify  correct username and password.
Read more
I currently use a folder software called Folder Lock Version 1.8.8.
A few weeks into using the software I get this error while trying to access the software “Error debug privileges.”
The software works no longer and I need it.
Please help!
Read more
Hi guys!
I use zip file on my pc and when I attempted to do zipping a folder an error report came up.”Error 740: The requested software needs an upgrade.” Does anyone know what I can do to continue zipping my files without errors?
“Error debug privileges”, unable to use Folder Lock Version 1.8.8
Read more
For the last 3 days I have been unable to find the folder option in the files menu.
Some of my very private files are kept there but I am not able to get to them because I have to press the folder option first. I am at with ends.
Can anyone help me out?
Read more
My client, a medical research company, requested me to go and install a software for them. This software was to be added to Canfield imaging systems VISIA software package known as Mirror. This package was to provide the client with a solution to managing images, whose source was VISIA, more efficiently and in good standards. Presently, they can send images either one in a go or many in a go, using a format that is below the standards making them meaningless if you are not getting them from another VISIA system. However the installation also failed to complete because...
Read more
I just received a VPS and inserted the Response Assault on it. Then I went ahead to create an account but every time a prompt would come up in a box at the bottom right reading “An error 999 occurred.” I have tried many other United States based proxies but they do not seem to respond. Every other proxy from different regions seems to work though. Is there someone who has a clue?
I understand Error 999 in Yahoo Mail means you requested too much data. At the same time I own Scrape Box and it runs behind proxies very...
Read more
I have issues with downloading the Vipre Antivirus + Antispyware. When I try to download this software next error message pops up:
Error 1335. The cabinet file 'Data1.cab' required for this installation is corrupt and cannot be used.
This could mean a network error, an error reading from the CD-ROM, or a problem with this package.
I am really puzzled with this error report, so can anyone please explain what this message mean and how to fix it?
VIPRE Antivirus + Antispyware Installer Information Error 1335. The cabinet file ‘Data1.cab’ required for this Installation is corrupt and cannot be...
Read more
As I was starting my Grafis application, I attempted to Log On to the Model Files and an error message appeared on the screen “An error occurred while trying to read the font file...” Anyone knows what might have happened?
Read more
Receiving S.M.A.R.T. Status bad backup and replace error.Hard disk drive is bad or is going to fail soon
Read more
When printing to HP-6040, we are intermittently getting "Failed to print" error. This is happening for all staff and there appears to be no obvious pattern as to which jobs print and which jobs fail to print. For example, this morning I successfully printed an MSWord document, then a PowerPoint document, but when subsequently printing another MSWord document it "Failed to print".
Read more
