Archive
While connecting Windows 7 client PC with Win 2003 DC through Remote Desktop, the PC does not find the server name in the explorer and returns the message after some delay “Windows cannot access \ServerName. The IP address and domain can be pinged fine. Is Win 7 Client supporting the connection with Win 2003 or are there any other recommended settings for connecting with my Win 2003 DC?
Read moreMy requirement is to implement the best version of Moodle as a course management system, with a web hosting service that already has Linux, Apache and MySQL.
I'm thinking of starting this on Windows. Is Moodle installed just like common software (via Windows Install), or is it a much complicated process? I'm also considering Linux. Is it better to start with the latter? Thanks ahead for the help.
Read moreWhile creating the NTBackup in Windows Server 2003 SP2 (which is also the domain controller and exchange server), the network connection aborted and Windows Server shows the error “Generic Host Process for Win32 services has encountered a problem and needs to close”. This is also happening when editing, deleting or even running that NTBackup scheduled file. Due to this problem I can’t ping with the internet server and it also does not work as DNS server and emails got lost and even nobody gets access to the use the internet browser well. Should I need to restart it as...
Read moreWhile changing the Language Pack from English to German, the user in German Language Pack experience the UM Bug that changes the German to another languages like Danish and Netherlands. While the English is working fine it happens in German after the change is made Personal Options - record your greetings. The same changes to German again when the user go back to the menu of languages. How to Fix that UM Bug?
Read moreHow can I automatically insert my email signature into every new mail that I am composing in outlook express every time. The method I am currently using to insert the signature is to right click on the red x, selecting properties and then go to the source of image in which it is located in the computer. Is there any way to use automated function to insert signature?
Read moreIn my server (with Kerberos client), I keep getting a "KRB_AP_ERR_MODIFIED" error from the server host/Server.Server.cr.
What could be the problem on my Kerberos server? Please advise.
Read moreMy LAN is having problem with connecting 2 home PCs that are using Win XP, few days ago the network was working fine, but now it seems like I can’t ping with the host IP. It works well with the client IP and I can access to it. Is there a problem that the LAN is not working properly and what steps should I follow?
Read more
How I will ping and manage my Windows XP SP3 Clients (DHCP) from my DC (WinServer2003 R2) when they both obtain their IP addresses from the same DHCP server? How can I make my DC to function as a controller to manage my Windows XP clients and is there any need for Windows XP clients to modify their recommended settings of DHCP to obtain their IP addresses that ping DHCP and DC?
Read more
While running command line processor “Console 2” for the Windows, why that command appears for a while and then disappears. What is the method of launching that substitute command as it also does not show any prompt line?
Read more
I purchased AutoCAD 2011 installation disk for Mac, but I could not able to install it.
I uninstalled with the help from HelpDesk and then re-install it again.
I entered the product key correctly, but it still failed to install. What could be wrong?
Can someone tell me on ways to resolve this problem?
Thanks you in advance.
The installation failed.
The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.
Read more
