Archive
When I am trying to install Windows 8, the driver CD is not loading and exiting the installation. Please help me to find out the driver for graphic card. Please guide me to sort out this issue. I will thankful for all help and support.
Read moreI installed Nokia Suite on my Windows PC. Afterwards, I was prompted for a new version for my Nokia Suite which is Version 3.2.100. I installed the update successfully and created a backup before the installation. But I received an Error 12017. What is wrong with the Nokia Suite? I installed it again for few more times but still end up with the same error window. How can I fix this?
Update Nokia C5-03 Software
Something's gone wrong
There was a problem with Nokia Suite. Please restart the program and try again....
Read morePlease help me in AweSync installation. I am encountering this error every time I attempt installation:
“Lotus Notes software is not installed on this computer.”
How can I fix this? Any help is very much appreciated.
Read moreIt is possible to install V5R2M0 client access with 32 x Windows 7. But it is giving an error message when I am installing the same with 64 x Windows 7. The error message says ‘XCOPY File – two’. Please suggest me to solve this problem. Thanks in advance.
Read moreThe site http://racing4glory.com/fantasy-racing/ has a drop-down menu. When I view it using Mozilla Firefox, the browser shows the drop-down menu. However, when I open it via Internet Explorer, the drop-down menu is hidden.
How could this be fixed? Any help is appreciated.
Read moreI am using Share point Version 2007 and Lotus Notes Version 7. I am looking for help to create share point for displaying Lotus data. How can do this? Is there any application to do this? Is there any tool to do this? Or any training is available to do this? Can I use the XML for this? I have only very limited knowledge in Lotus.
Read moreI have an intranet site that has some files on it. I'm using Internet Explorer to browse the site. When I open a file, it shows an error message, displayed below:
“Internet Explorer has encountered a problem and needs to close…."
What can I do in this regard? Thanks ahead.
Read moreI have an external hard disk which has 1 partition, formatted in NTFS. I use this drive on multiple computers, with different logins, and with different operating systems (Windows XP and Windows 7). All files are plain old files, not OS encrypted or compressed. However, Windows 7 does not let me access some files, for I don't have "citing permissions".
Is there a simple way that I could access the files/directory on a partition, apart from taking ownership and setting appropriate permissions? I really find this process very tedious.
Thanks ahead.
Read moreSometimes the users are not able to log on to Active Directory Network 2008. It is getting failed to connect to domain controller. We are using 2 AD boxes. When this problem happens nobody can log in. It will longer for some minutes. If anybody knows how to fix this problem, please let me know. I will thankful for all help and support.
Read moreI am using SUSE and I want a Linux terminal command to search Unix hierarchy files with a pipe in their name, and rename them to dash.
Any idea as to how this can be expressed?
Read more
