Archive
Hello experts.
When I tried to upload some pictures to my Image library (using Default Photo album) via Sitefinity v. 4.2, I got a "Not Authorized" error message. After I found the error, the uploading function totally locked up and seems to have crashed.
Currently I am registered as an Administrator so I have the full administrative rights on the system.
But when I tried to re-upload the pictures, I found another error, and this time it's a "Value cannot be null" error message.
I have added the related screenshot for your analysis.
Read more
Hello everyone,
I have been running Acronis True Image (TI) Echo Workstation v9 for the last 4 years without facing any problems using Windows XP SP3. I received a new Western Digital (WDC) MyBook Essential 3TB drive from a client to set up. The TI Echo Workstation was able to run his workstation for the last 3 years successfully using WDC 2TB drives for image backup.
However, when we used the WDC 3TB drive, TI Echo Workstation would not respond after install.
I found the following error message while clicking on the TI Echo Workstation icon to run the program:
TrueImage.exe - Application error the instruction at xxx referenced memory could not be read' appName: trueimage.exe modname...</p> <a href=Read more
Hi experts.
Two days earlier, I tried to launch the PokerStars https://www.pokerstars.eu/) client, but then I found this error message:
I didn't expect this error to come out after launching.
I need to solve this error.
Please help.
Thanks a lot.
Error:
Update Failed
Signature Expired or Wrong Time Settings
Read more
Hello guys,
Sorry for disturbing, but today, I auto-updated Zmodeler 2.1 to 2.2 and now it doesn’t respond on my computer, and I get an error message.   Below is the image:
This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem
And I am unable to move back to 2.1 because the 2.2 update overwrote my 2.1 version.  So now I'm frustrated with a broken Zmodeler.  All the previous versions of Zmodeler are working properly , but not 2.2.  I've been running a registered Zmodeler for the last few...
Read more
Hello experts.
I am using Windows XP Pro Service Pack 3.  Everything was working perfectly before until recently.  During the last two bootups, I got the following error message.  I have added an image but the image is too little, and you might not read it properly.  It says:
Installer.exe
Installer.exe has been encountered a problem and needs to close. We are sorry for the inconvenience
If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem
We have created an error report that you can send to...
Read more
Hello experts.
I use DVD Decrypter to write my ISO document from DVDshrink (http://www.dvdshrink.org/), but I am receiving the following error message:
DVD Decrypter
DeviceIoControl(FSCTL_LOCK_VOLUME) Failed!
Device: [1:1:0] TEAC DVD+RW DV-W58E D.0C (E:) (ATA)
Unable to lock volume for exclusive access.
Reason: Access is denied.
Does anybody have any idea what this error means? I need to solve this error. I hope this screenshot helps in debugging the problem.
Need your help.
Thanks a lot.
Read more
Hello experts.
I just updated my Hellgate: London game client.  After updating, all I find this strange error message.  See the gibberish on the error box below:
Also, I am not able to start the game in any way.   Then I uninstalled it and again installed the game.  I also tried restarting my PC, but it didn't do anything.  I don't know what to do now.  Need your help. Thanks in advance.
Read more
Hello experts.
Our users are having problems with OfiPro (https://www.ofipro.com).  During our program, we get this error right when we use the forum.
We want to know if there are any probable solutions to the problem. Please help me solve this. Thanks in advance.
Read more
I am utilizing the Yahoo User Interface (YUI) Test Standalone beta (yuitest_1.0.0b1). When I tried to run the yuitest-coverage.jar test coverage implementation on my JavaScript files, I got this message on the console:
line 50:0 no viable alternative at input '}'.
I am trying to implement all documents within a directory.
For what it's worth, I am operating the coverage JAR as a Java ANT task from Eclipse (Helios).
Is there a technique to raise the verbosity of the error messages from the reporting code? Perhaps something that can help me isolate which file the instrument is complaining about?...
Read more
Hi all.
I just got a full IS built on top of the Vaadin/Spring/JPA stack.  Then I ran .jsp pages via Spring security to catch clients logging in and out.  I also found that the session timeout was set aggressively to 7 minutes for security reasons, so users found themselves getting kicked out and having to log in again after the set time.
When we used Vaadin 6.4.8, everything seemed ok.  But after the system-wide upgrade to Vaadin 6.6.2, a weird error came out when session is timed out. Check this out:
Read more
