Archive
Hello experts,
Just now from my desktop, I accidentally deleted the “My Computer” icon. I don’t know how it occurred, I must have dragged it out, well, it was really accidental. Please let me know how I can put it back? I don't even know where to find it.
Need your help. Thanks in advance.
Read moreHi,
How do I resolve the following error message?
Error: The message could not be sent. There is not enough Disk space.
This occurs when I try to send an email through outlook. Where should I start doing the cleanup? Is it on my side or the recipients’?
Please help. Thanks.
Read moreHi all.
I am having trouble while trying to open CSK hdf5 ScanSAR Wide mode L1A imagery (https://sentinel.esa.int/web/sentinel/toolboxes) and I'm receiving the error attached below. I am able to open CSK hdf5 Strip Map L1A imagery successfully. So I need to know what is causing the error in opening this data. I would be grateful for any assistance about this issue.
The error says that this problem is linked with the metadata but the imagery can easily be viewed in other HDF viewers without facing a problem. I am unable to process it in these other viewers.
Hello
I want to know one thing.
I have to change the taskbar position in Windows Vista Operating System.
What are the steps on how to accomplish it?
I am new to Vista and am not quite sure how to navigate around it.
Please help.
Thanks a lot.
Read moreHi
I have a question. I know this happens a lot, but how do you efficiently solve the problem of a pc that suddenly freezes? Is there no other way except to force restart the computer? Are there any preventive measures on how to avoid this? I am running on Windows OS.
Please answer. Thanks.
Read moreHello experts
I am using the first release of JRE. I would like to know how to start Visual Paradigm on it.
When I try, I get a blank screen.
Can somebody please help me with this one?
Thank you.
Read moreHello
In Linux OS, it is close to impossible to install Microsoft Office. (If you persist, you can install it using Wine.)
With that said, how can you accomplish installing MS Office in Linux? Is that even possible without using third-party software? I would like to be able to open MS Office documents on Linux. Any ideas?
Need your help. Thanks.
Read moreHi
I am reinstalling my Windows but after that I am getting some problems. My sound/video/modem/printer are not working properly. I believe it happened after the reinstallation. What to do now?
Please help. Thanks in advance.
Read moreHi
When I try to shutdown in Windows 98 SE, it does not shutdown properly or it won’t restart properly. It just hangs. What to do now?
Read moreHello,
The progress bar on the monitor approaches completion during boot-up but I can’t seem to access Windows after that. What should I do?
Need a solution. Thanks in advance.
Read more
