Archive
Hello experts,
This error came up when I attempted to install iTunes:
- “VBScripts required for this application”
Where do I find this VBScript? I cannot understand this. I thought installing iTunes is not that complicated.
Please help. Thanks a lot.
Read moreHello experts,
I don’t know about the following message. Change Junk email protection level in Windows mail! Please give me the details of this message. Where can I change the settings? Thanks in advance.
Read moreHello
In Internet Explorer 7, all application is freezing. The browser sort of stops working. It keeps on doing that even if I restart. How can I solve this problem?
Please help. Thanks in advance.
Read moreHello
When I try to boot my computer it began running Disk Check. I just allow it to finish the check and it gets no error. My question is, why does it keep on doing a disk check? Is something wrong with my system? How do I turn that off?
Please help. Thanks.
I have a problem. I am getting two errors. The first is this error message “The system cannot find the path specified. However, the drive-letter is listed in (My) Computer and accessible from non-elevated Command Prompt” and this “access the “network drive” using elevated command prompt”. I’m at a loss as to what it means.
Need a solution. Thanks very much.
I have a simple question. How do I configure the Auto run Setting?
Where can I find the utility to set it up?
I want to be able to disable/enable this setting but I don't know where to find it.
Need your help.
Read moreHi
I would like to disable document sharing on the network. How do I change the settings and how do I configure that?
Is there a way wherein I can set all PCs in the network to disable document sharing, and do it without having to go to all the PCs to set them up like that?
Hello
I have a problem with my System Restore. When I try to run it, it says it has encountered a problem and has to close. I need to restore my system to the last good configuration but I can’t get past the error and I don’t understand where it is coming from. Is my system crashing?What should to do?
Need your help. Thanks in advance.
Read moreHi
When I try to open my laptp.I always find the following error message (found below). I need to fix this.
Here is the problem file c:windowssystem.exe..
Please help.
Thanks a lot.
Read moreHi,
I have a question. How do I solve a Windows 7 activation error? It keeps on popping up every time I turn on my computer. Please answer.
Thanks in advance
Read more
