Archive
Hello experts,
The icons showing on my desktop are too large, and I would like to change it to a smaller size.
I am using Windows 7. And also, I would like to change the screen resolution.
How do I do that?
Please help.
Thanks a lot.
Read more
Hello
I am using Windows Vista on my pc and I don’t like how the icons are spaced.
Is there a way to change the spacing between the icons?
Where should I start?
Thanks very much.
Hello experts,
After upgrading to Vista, I am configuring my IE7 add-ons. I configured it like how I did it in IE6.
But then I am facing an error; IE7 randomly shuts down.
I don’t want to reinstall Vista. Should I just uninstall IE7 and reinstall it?
Would that solve the problem?
Need a solution.
Thanks in advance.
Read moreHello experts
I have a simple question. I want to defragment my hard disk. I am using a Windows 7 operating system.
Please help.
Thanks a lot.
Read moreHello,
A new window starts but I get no search options in there, I cannot see the address bar.
I want to solve this problem without reinstalling Windows XP.
Is it possible?
Where can I find the search bar?
Need your help.
Read moreHello
I want to use one of Help and Support's recorded troubleshooters to solve a specific subject, but I am getting an error message which basically says that I am not able to use the Help and Support.
How can I solve this?
Need your help.
Thanks in advance.
Read moreHi experts
I need help here. I am new to Windows Vista and would like to know how to modify the folder icons. I can’t navigate through the new operating system and I am stuck.
Please help. Thanks in advance.
Read moreHi,
I created a user account and I wanted to change the name after I created it. When I tried to rename the folder, it shows that I can’t do this because I don’t have authorization. How can I change the folder name?
Please help. Thanks.
Read moreHello experts,
I am facing a problem. Almost all the icons on my desktop are upside down; yet the arrow/cursor is same.
What happened here? I don’t remember making any changes in the settings.
How can I fix it?
Please help.
Thanks in advance.
Read moreHi
I want to remove ActiveX Controls in Internet Explorer. How can I do it? Can somebody guide me through the whole process?
Need your help. Thanks in advance.
Read more
