Archive
Hello TechyV,
Windows 8 just launched their consumer preview yesterday! I would like to test it out on my computer but I don't want to mess my current setup.
What's the best way to install it without destroying anything on my computer? Thanks in advance!
Read moreWhile trying to uninstall Silverlight due to Windows XP update that cannot be installed, I got an error “The installation source for this product is not available. Verify that the source exists and that you can access it.” I tried to remove Silverlight but it is not help. Does anyone encounter the same issue? Help please.
Windows-7 has better networking speed as well as some extra features than all other older windows version like windows Vista and Xp.
But we find it sometimes that the speed of windows 7 is slower than Windows Xp which is not supposed to be. This speed can be easily made faster by deactivating some of the unused advanced features.
And sometimes we find much slower when we try to access Sun and Linux system as a result data access and transfer process troubles and takes longer time than as usual.
Read moreIn system analysis and Design,why is it there is most project development failures are attributed to poor and leadership management?
Read moreHow can I pin an item with my iPhone 4S using the Pinterest iOS application of Apple? Please send me the method. Thank you.
Read moreHow can I clear the cache on my BlackBerry Curve 8520 browser?
I tried it in the Menu key and Cache Operations but it did not work.
Read moreHow can I disable the 4G/LTE on my Motorola Droid 4 smartphone? I need to disable it since it always drains my battery. Any help will be appreciated.
Read moreMy Android phone always shows ads in my notification area and this shows almost every day. Does it mean my phone is infected with a virus?
Read moreI lost the shortcut icons of my Motorola Droid after updating Froyo 2.2. How can I bring the icons back to the Home screen?
Read moreHow can I get speedy my computer when I work with it?
Can any one give me advice to remove the problems?
Read more
