Archive
I encountered a problem when I try to use Sharepoint. Here is a screenshot of the error message:
Server Error in '/' Application
Cannot connect to the configuration database.
Description: An unhandled exception occured during the execution of the current web request. Please review the stack trace
Exception Details: Microsoft.SharePoint.WebPartPages.WebPartPageUserException: Cannot connect to the configuration data
Source Error:
An unhandled exception was generated during the execution of the current web using the exception stack trace below.
Can this still be fixed? How? Thanks for the help guys.
Read moreWhile working with a client on a new VDI design and accomplishment an issue popped up which is associated with some of the configuration items in View 4.5 with Microsoft SQL Server 2008. The problem occurred in the configuration of the view proceedings database. On trying to include the SQL Server 2008 database to the View Admin Console the computer kept creating the same error message, although all the data was right and the database was already there on the server. I have included a screenshot of the error, and the text it contained, below:
Hello every one,
I am facing at present a weird error on one of my forums. Each page is showing a 'Database Error' message as follows:
Database Error: The database has encountered a problem. Please try the following:
* Load the page again by clicking the Refresh button in your web browser.
* Open the www.crackingforum.com home page, then try to open another page.
* Click the Back button to try another link.
The www.crackingforum.com forum technical staffs have been notified of the error, though you may contact them if the problem persists.
It should be made clear that I edited nothing...
Read more
On trying to start the configuration wizard in SharePoint 2010, I faced the error message as follows:
Failed to create the configuration database. An exception of type System. InvalidOperationException was thrown. Additional exception information: This implementation is not part of the windows platform FIPS validated cryptographic algorithms"
Products and Technologies Configuration Wizard
Configuration Failed
One or more configuration settings failed. Completed configuration settings will not be rolled back. Resolve the problem and run this configuration wizard again. The following contains detailed information about the failure:
Failed to provision the SharePoint Central Administration Web Application.
An exception of type...
Read moreWhen I started the installation process of Cisco Unity, the error message comes next:
“The following problem was found while verifying that the system meets the installation requirements: Unable to open a SQL connection to the Master Database. Call Technical Support.”
What does this mean? Can it be resolved without having to call tech support? Thanks for the suggestions.
Read moreHi All,
I managed full installation of my server from scratch and did it in this order:
- Windows server 2008
- Active directory with DNS
- SQL server (all services running as administrator)
- IIS
- Master Data Service (MDS)
As MDS was completely installed the configuration manager was also in progress. I faced the error as follows:
“An unexpected error occurred: Some or all identity references could not be translated.”
I had also fully installed similar systems in different servers although without IIS. It is good that I faced no errors, yet no doubt without IIS I was unable to go very far in the MDS configuration!...
Read moreI was in a lot of trouble due to this error for the last couple of days. I used the option of setting up Web Configuration for Master Data Service (SQL Server 2008 R2) from Configuration Manager.
The screen shot of it is as follows:
I was logged in using my domain user account, and I had used User Name as “domainuser” instead; the error message continuously popped up each time. My domain account has administrator privileges, but even that didn’t help at all. Any help will be greatly appreciated.
Error:
Application pool not valid
The user does not match...
Read moreAfter I had upgraded Lotus Notes Client to version 8.5.3 it could no longer connect to the server. Instead it shows this error message: "Sametime Login Failed - Reason: Unable to log in to the Sametime server x because this client is not authorized. Please contact your system administrator."
Any ideas out there? Thanks.
Read more
When running the IBM Lotus Domino Access for Microsoft Outlook Setup, I am facing the following error when trying to check / load my lotus notes ID;
"Operation stopped at your request"
What is wrong with my system? What can I do to fix it?
I need some help.
Thanks very much.
Read moreIt has been my routine to take a look at my e-mail box user interface, refreshing my mailbox soon after my Notes 8.0.1 upgrade.
The New action button is not available to me for saving attachments to a Quickr place, I presume. On choosing the Preferences menu item I faced an error message as follows:
“The specified database driver does not support this function.”
The status bar indicates this message: “qkr”: “NoCache”
In my opinion the "database driver" is regarding the "qkr" option in the @DbCommand: as I had an ndbqkr.dll file in the directory of Notes client...
Read more
