Archive
What is the difference between inserting picture from Clip Art & from File?
Read moreHi guys,
When trying to connect Change Lister to SQL server using the Microsoft Dynamic server, I get the following error message.
What should I do? Please help me.
Error:
The Microsoft Dynamics NAV Server cannot connect the Change
Listener to SQL Server because of the following error: Cannot
open database "Demo Database NAV (6-0)" requested by the
login. The login failed.
Login failed for user 'NT AUTHORITYNETWORK SERVICE'.
Read moreWhat is the difference between slide transition & slide show view?
Read moreThe Adobe Fireworks CS5 displays a new error message, which says, “running out of memory”.
How do I address this problem?
Help! Thanks.
Low Memory Options
What is the difference between blank presentation and design presentation?
Read moreWhat is the main difference between visual translation & text translation?
Read moreHi, everyone,
How do I stop the error message popping up when installing a program?
Please help me solve this issue.
I have pasted the error message below.
Some updates were not installed
Failed: 1 update
Error(s) found:
Code 8024290D
Read moreDescribe the main interfacing elements of MS PowerPoint window .
Read moreDG41TX blue screen when plug in HTC Windows 7 phone and when run Zune.
Also slow boot says EB then BA.
Read moreWhile trying to change some settings in Windows 7, I got an error message that goes something like this:
"Windows Firewall can’t change some of your settings. Error code 0x80070424." A screenshot is provided below.
Please share with me your solutions to get me out of this problem.
