Archive
Some of my colleagues and I have been encountering an error with Windows Media Player. The error keeps saying the WMP should be re-installed for the different version. Moreover, it states that the system needs a different version of WMP and its reading a different version, but I don’t want to change my WMP again.
Help me out here please. My colleagues and I will be eternally grateful.
Thanks!
The file wmploc.dll has a version...
While I was half way through the installation of Nitro PDF, I got the error message below:
Nitro PDF Reader Setup
An error occurred during the installation of assembly 'Microsoft.VC80.CRT,version='8.0.50727.40S3",type="win32",publicKeyToken="1fc8b3b9a1e18e3b",processor Architecture="x86". Please refer to Help and Support for more information. HRESULT: 0x80070002.
I am using a 32 bit Windows Home Premium with 1.6 Intel Atom processor and 2GB RAM.
I would like to use Nitro PDF because Adobe’s is too slow and boring.
Can anyone help me fix this problem?
Thanks in advance.
You guys are the best!
Read moreWhen opening a Adobe Reader file from a client mapped network drive using client to server content redirection, I get the following error message
There was an error opening this document. Access denied.
I use XenApp 5 for Windows 2003 server. I uploaded a screenshot to better understand my problem.
Please help.
Thanks!
We upgraded Adobe Reader at our terminal server where our Dynamic GP application is located.
Until the up gradation, we were able to upload and view the PDF files using the OLE container, but after that, we were not able to view the existing and even uploaded PDF files. As what the screenshot below says, the OLE Container failed to create object.
Help badly needed.
Thanks!
Help!
When I tried using Skype this morning, I got the “Skype has stopped working” error message. So I checked the windows task manager where I found two residuals. So I ended the Skype.exe and skypePM.exe files.
Confirming that all files are closed, I restarted the Skype for Windows. I was able to view all my contacts, but the recent contacts were not there. When I restarted the system, I was able to find the contacts in Recent tab but no contacts were shown being online.
Skype
When compiling FPGA, I get an internal error message. The program I am working on is complicated and the size is of 801KB. I used 15 target-scoped FIFOs to transfer data within the target. I have attached the log file. Please help me figure this problem out.
Error:
Code Generation Errors
Error
Internal software error(s)
Details
An internal software error has occurred. Please contact National Instruments
technical support at ni.com/support
Method Name <b> Compile For Target</b>
Read more
I have been an avid Adobe user for quite some time now - from the simple Adobe Reader to After Effects.
However, I have seen the same error over and over again in almost all the Adobe Software products I’ve used. It’s the 2739 Error. This always pops up during installation and I always have to ask my friend to fix it for me. I don’t want to bother him anymore so can anyone help me with this?
I provided you with a screenshot of the dialog box.
Thanks in advance.
What types of programs or information is stored in ROM?
Read moreEach time a page with an embedded video is loaded, I get the error message “Error #2044: Unhandled IOErrorEvent:. text=Error #2035: URL Not Found.”
Inspite of this, I am still able to dismiss the error message and continue viewing the video, but it’s quite annoying to do so every time.
Any help would be appreciated.
Read more
The upgraded version of ShoreTel 11.0 server works fine with no issues at all. So I tried to install it to the new ShoreTel communicator to end-users and to our Citrix / Remote Desktop Servers. When I log in without administrator/user permission in Citrix and run the new client, I get the following error message: "Encountered error while attempting to connect to server."
Why is this so? Is it not supported anymore? Please help. Thanks in advance.
Read more
